Question about Toshiba Portege R100 Tablet PC
Taking apart a Toshiba R100
I want to swap the keyboard for a new one that I have.
I have removed all the back panel screws but the bottom won't come apart. Is there a catch?
  • Toshiba Master
  • 32,281 Answers
Probably, could have some slide catches at the top edge of the keyboard instead, need a thin blade screw driver oh lift the keyboard. Some laptops mark the screws with the letter K in indicate keyboard screws, some keyboard screws may be hidden under the battery pack, CD/DVD drive.
Posted on Nov 13, 2008
Portege R100 (Toshiba). I have not used this laptop in over a year and can not rem the bios password I'd set. Tried all I could think of. Is there any way to reset the password on this?
Hi,yes there is but you'll have to open the system up,if you have no prior I.T expertise I'd suggest you take to a qualified Technician,but if you do here is how:First remove the Battery,then uncouple the system taking of where each of the screws go to then locate the CMOS battery(small battery Lithium Ion mostly in the shape of a cent or smaller),it may be underneath the keyboard or just behind once the external cover is open.unplug it from the system for about an hour or two reconnect it,couple the system and boot,go to Bios,reset Date and Time and save,then exit.
Dec 31, 2010 | Toshiba Portege R100 Tablet PC
Toshiba R100 suddenly very slow(!)
I'd suggest sending it back to where you bought it, this sounds a lot like a factory problem and it should be covered under warranty.
May 27, 2009 | Toshiba Portege R100 Tablet PC
How to replace r100 keyboard? i took the bottom and then i don't know how to take the keyboard
Assuming this is the same style of case as the older Portege models, the bezel on the bottom of the keyboard or on top between the keboard and the display should pry off (although there might be a screw or two into it around the hinge on the top) separately- they cap tabs on the edges of the kbd, or screws.
Apr 13, 2009 | Toshiba Portege R100 Tablet PC
How do I Install my memory in my Toshiba R25-S3503?
ur laptops memory slot is located under the keyboard, u have to carefully remove the thin cover from the top of ur keyboard to reveal the 2 screws, then un screw them to reveal the RAM cover. unscrew the two screws on that to reveal the RAM. be sure to take out ur battery b4 u do this.
Mar 27, 2009 | Toshiba Satellite R25-S3503 Tablet PC
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
Dismantelling Averatec 3500 series tablet PC
I have this same laptop. It is pretty simple to tear apart. Is there any specific areas you wish to access or did you want to just take it completely apart? If you are going ofr the keyboard ribbon or the touchpad ribbon, just undo the two screws out that are located behind the pivot point of the screen, then open the laptop and remove the small plate. This reveals access to two more screws (2 silver, 2 black). Remove the silver ones not the black ones. The black screws remove the lower shell assembly. Once the silver screws are removed the accessory bezel can be removed. ( the one with the power button and lights)
There are yet two more screws that lock down the keyboard. Remove them and pivot the keyboard toward the touchpad. You can now safely remove the keyboard.
Jan 28, 2009 | Averatec 3500T60 Tablet PC
Toshiba R100 keyboard not working
I did the same some two years ago, with the R100 on. I switched everything off, dismounted the computer body (not the screen)up to the last screw, and dried that sweet coffee from everywhere where I found it. Mostly this was the keyboard and mouse. The motherboard is luckily protected by some plastic sheet.
Regarding the keyboard, after disconnecting it from the motherboard, I washed it completely under flowing water and then let it dry for several days. In the meantime, I used a USB one. Since then, I used the same keyboard for two years until now, when it died, apparently rather from some motherboard-related reason than water. So I think - you may get a new keyboard, but if youre lucky, you may as well revive this old one.
Jan 07, 2009 | Toshiba Portege R100 Tablet PC
Toshiba without battery
1. If the batteries are dead then there's no way that you can charge them again. You're better off purchasing a new one. You can purchase one online by visiting the ToshibaDirect website or by calling them on 1-800-316-09202.
2. Yes, you can use the power cords to run the computer. Just plug them in using the power cords even with the batteries removed and it should work fine.
3. Yes you can but you might experience some current fluctuations. This is negligible on a CMOS battery though.
Aug 14, 2008 | Toshiba Portege R100 Tablet PC
TC1100 keyboard replacement info
If you are replacing the keyboard component (i.e. the actual keyboard) the process is straightforward. You will need jeweller screwdrivers as the srew (torque and philips are quite small):
1. remove all outside screws on the back of the keyboard
2. as per wkuk above you (thanks!) you will see 4 small covers
3. Pop the covers off with a pin they are lightly glued on
4. Remove the 4 screws (philips head)
5. Turn the keyboard so the keys face the table
6. Separate the case exposing the back of the keyboard
7. There are two screws that need to be removed that hold the keyboard in
8. Remove the tape that holds down the ribbon cables
9. Two ribbon cables attach the the keyboard. Be VERY careful and disconnext the slim one from the existing keyboard. Disconnect the second cable from the keyboard body (as the kew keyboard will plug in there.
10. Remove the keyboard and replace with the new keyboard
11. Reverse the steps above.
The real key is to be careful with the cables. Hold the entire cable firmly as these types of connectors can tear. When you initially slowly remove the cables you will gain some idea of how far the cable goes into the connectors. Although I've done lots of fixes on hardware this was my first time doing my keyboard for my TC1100 and the start to finish was 15-20 minutes. If in doubt, take a phot of the keyboard after you've removed the keyboard.
Cheers,
David
Jun 09, 2008 | Compaq tc1100 Tablet PC
Toshiba M400 tablet wont start
hello jpmca
try to take off your fan cable
here http://slashstar.com/blogs/alex/archive/2006/09/30/Toshiba-M400-Fan-Hack.aspx
and try to release the memory sodimm, release the battery and plugin the power cord again
if problem solve try to updated your bios for fan noise solution
here
http://support.toshiba-tro.de/kb0/TSB6A01KJ0000R01.htm
oke
cropp
Mar 15, 2008 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba Portege R100 Tablet PC Logo
196 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
