ERROR CODE ON MITA DC1205
I WAS MAKING COPIES ON MY MITA DC-1205 AND IN THE MIDDLEOF IT, I HERD A LOUD CLLANK AND ERROR CODE C3 SHOWED UP AND IT STOPPED.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check your scaning gear
Posted on Nov 11, 2008
  • olayoju victor Nov 12, 2008
    this a gaer (clutch) that connected the pulley system & the main motor  together .so the scaning w ill stop at a position. open the back cover, you see the white gaer with pulley which control the scaning system.replace the gear
My copier mita dc 3060 showing error code c 210
Hello Manuel sorry for your machine to be in that stake but have you tried to check on that paper conveying motors because that error is for those lift motors try to go on your machine run this code
press status/job cancel
enter 1087*2 twice
enter 906 and then you will see execute
the you press start to see whether it will stablize
Sep 25, 2012 | Kyocera Mita Toner 37085011 for DC-3060 &...
MITA copier DC-2360, error code C610, fuser replaced. How to reset the error ?
IF you have corrected the problem that caused the C610 (broken fixing heater wire), then the error is cleared by turning the machine power switch off then back on.
Jan 07, 2011 | Kyocera Mita Office Equipment & Supplies
MY MITA DC1205 WILL NOT TURN ON FAULT FLASHING ''C6'' ANY IDEAS?
You might have a broken transfer charger wire or shorted out corona blocks, It is the piece that sits underneath of the drum
Jan 07, 2010 | Gestetner Office Equipment & Supplies
USER MANUALS OF MITA DC - 1860 PHOTOCOPIER
I have a Mita DC -1860 it wont make any copies it say AP what is this AP mean thanks
Jul 14, 2009 | Ricoh Aficio 1035 Copier
Black stripe in middle of copies 1/2'' thick whole page
Most likely it is a bad drum cleaning blade. It will need to be replaced. This machine is old...good luck.
Jun 25, 2009 | Kyocera Mita Office Equipment & Supplies
Error code 260 for a MITA DC 6090
its a problem in your cooling and drive system... consult kyocera for an explanation of this code...
Mar 15, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Mita photocopier DC 1205 won't turn on
That's a very old machine, most likely the power supply is cooked. I know I replaced a lot of them back in the day. A machine at that age, and capablility, is much cheaper to replace than repair these days
Jan 29, 2009 | Office Equipment & Supplies
Copies are very dark; almost grey
You need a service engineer to clean and service your copier.
Jan 18, 2009 | Office Equipment & Supplies
Mita error code
I think that stands for OPEN. Check to make sure that all the doors are closed. Right side, left side door, and also front door.
Hope this helps.
If you still have the OP message, then let me know and I will dig out my books and look it up.
Good luck.
Mac
Mar 12, 2008 | Office Equipment & Supplies
Mita DC-1205 Copier
Open the front door... on the right is your toner. It is a cartridge that inserts long-ways (front to rear) into the machine, and should be white or ivory in color. DO NOT remove the old toner cartridge without having a replacement on hand. The new cartridge will have a plastic "cover" on it that assists in releasing the toner cartridge locking tab, and "seal" the old cartridge as you remove it from the copier. The cartridge opening is face down upon installation into the machine, and you may get some spillage if you remove it without the cover. DO NOT remove the new cartridges mylar seal until AFTER you install it in the machine!!! There should be a picture label inside the front cover showing how to replace the cartridge. And there is a pictorial diagram on each new toner cartridge box also detailing this.
Use only MITA DC 1205/1255/1415/1435/1455 toner, OEM #MTA37041013. Should run you about $12-$14 per cartridge retail, or cheaper if shopping around (I sell them for $11.99). Do not use copystar brand for the same equipment. Although it's the same toner, the shape of the cartridge is slightly altered, and may not "fit" into the machine. I forget how it goes, either Copystar will work in Mita, and not the other way around, or vice-versa. Either way, better safe than sorry.
Oct 24, 2007 | Office Equipment & Supplies
215 people viewed this question
k24674
jasbo
jasbo
