Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
How do you open Garmin 360 to replace battery
I want to open my Garmin 360 to replace the battery but there are two screw under the antena assembly. please help..
email me at please
    SHARCNET-USA May 11, 2010
    wow...another link to the infamous Nuvi 760 video. A nuvi 360 is in NO WAY the same as a Nuvi 760. If you follow the 760 video, I guarantee you that your will damage your Nuvi 360.
    I have received so many damaged units in for repair from that video......
    Do-it-your-selfer beware!
    - Jim
    Please do not attempt to do this yourself. You need the proper tools to remove the screws and a special tool to take apart the case. I've had many people send me their Nuvi after trying to take it apart. The results have been gouged & dented case, lost hardware, cracked LCD screens and torn flex cables..... please.... don't try to do it yourself.....
    - Jim
  • 19,396 Answers
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
See also battery_repair.
Posted on Apr 10, 2009
How to open it to replace battery?
U need special miniature screw driver set to do the deed. The screws are located under the stickon tag that runs for the entire length of the unit on the bottom. (For Garmin GPS)
When you go to open the unit do so very slowly because on one side of the unit there is a ribbon connecting the front to the back of unit and if you open the wrong way you will break it. Carefully remove old battery, replace, and put back together.
Oct 08, 2015 | GPS
I have a 276c garmin, use it off road, in the forest I lose reception, in open area I do not. My buddies have the garmin 60 series and they do not lose reception in the forest. Any suggestions? Thank...
Try using an external antena, these are availble from Garmin, all you do is remove the existing arial and plug the lead from the external antena in. Then mount the external antena on your roof.
Oct 26, 2010 | Garmin GPSMAP 276C GPS Receiver
How do you open the garmin nuvi 360 to replace the battery
Please don't try this yourslef. You risk damaging the unit. Please see this link for more info:
- Jim
Oct 25, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Losse antena
Did you purchase this unit new? If not, someone may have taken the unit apart and lost a small spring out of the antenna assembly. If you place the unit, display side down, with the antenna hinge away from you, there are two small phillips head screws on the right side. If you remove these screws, a small plastic endcap for the antenna assembly will come loose and the antenna can be removed. Where the endcap and the antenna are hinged together, there should be a small spring that puts tension on the antenna. If the spring is missing, the antenna will not remain in position.
Oct 04, 2009 | Garmin Quest GPS Receiver
Garmin Nuvi 660 dead battery?
Here's a video demonstrating how to change the Nuvi 660's battery from newpower99. I hope this helps. Peace, Craig
(do not delete)
Dec 11, 2008 | Garmin Nuvi 350 Car GPS Receiver
Battery replace
Flip the unit over so it is resting on th screen with the on switch at the top you will see the reset and S/N tag. Pull this plastic tag off with twezzers or a knife. This will expose 2 torx screws size T-5. After removing the torx screws, right under the S/N plate sticker is a mount hole, locate this then pry apart with screw driver, be careful prying apart as there is a flex cable taped down to your pcb board. Remove the flex cable by opening the latch for it, there are 2 latches one small and one large and the cables are taped to the pcb board. Remove the speaker jack wire with tweezers.Next with a small jewlers screwdriver remove 3 phillips screws size ph00 from pcb board. Lift the pcb board out and disconnect the battery wire underneath. Next remove battery, it is stuck down with double sided tape and takes quite a bit of force to remove. It is a Garmin LI-ion 3.7v, 1.25 AH battery.
Aug 28, 2008 | Garmin nuvi 200W GPS Receiver
Pry off the face by gently lifting up just under the Garmin lettering. Undo the 4 face screws. gently pull the unit apart. Keep note of how the antenna goes back into place as it will follow the face forward. There is a shield with two screws holding the battery in place. The plug connected to the battery also houses the speakers so you will need to splice the new battery in.376ed8e.jpg11ffdaa.jpg
Jul 25, 2008 | Garmin GPS
Flashing question mark and can't get directions.
Try resetting the unit first. The reset button is located under the face plate. It lifts off by lifting right under the Garmin name.
Jul 15, 2008 | Garmin StreetPilot C330 GPS Receiver
I had the same problem recently... What I did was open the front casing and hit the reset button under the cover, then it turned on while plugged into the car adapter.
Dec 29, 2006 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
1,583 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
