Fuser How do I know if I need a new fuser. The cartridges are new, but when I print the colors (all colors plus black) are very faint. The black is almost gray. Would a new fuser help this problem?
  • gail_bentz Nov 11, 2008
    It is a Dell 1320C Laser Printer.
  • cpszan Feb 04, 2009
    Dell 1320c, even with new black toner, prints light grey
  • 146 Answers
The fusing unit uses heat and pressure to bond the toner to the paper. Normally poor fusing is evidenced by repeating images or by the print smearing when you rub your fingers across the paper. One fuser roller (the heat roller) is probably aluminum with a teflon coating and the other one (the presure roller) is a type of rubbery material and is often orange.
By your description you mentioned cartridges and that the printer is a full color printer. Is this a laser printer having toner cartridges and imaging units? I just want to make sure you do not have an inkjet printer as they do not use fusers.
The washed out prints you speak of sounds more like a transfer issue such as the transfer belt, transfer charge roller, etc...
Please tell me the brand and model of your printer and I will be more specific.
Posted on Nov 11, 2008
HP 2600n Laserjet Ghosting. Prints multiple, faint repeats down the page. Changed all toner cartridges, still happening
Perform fuser cleaning procedure. If not helpful, replace the hot fuser roller. When worn out it collects toner and may lead to repetitive image.
Mar 09, 2017 | HP Color LaserJet 2600n Printer
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
Printing very light Okionly B410d printer usesblack toner cartridge
Try performing a stop test. Send a test page and turn it off mid print. Retrieve the page from the printer to see if the image is readable before it went through the fuser. If so the the fuser may need to be replaced.
Jan 16, 2014 | Oki Electric Industry C3300n Laser Printer
My HP 3700 Laserjet printer is printing black specs
Examine the fuser and see if it has those specs on it. If so, the cleaning blade is not removing all the toner residue and will need replaced.
Sep 30, 2017 | HP LaserJet 3700n Printer
The copies are dirty, with black long tracks!
I would suggest either a fuser problem, If all Colors affected, or the Black Toner Cartridge. The Below chart may help isolate which component is malfunctioning. Repetitive image defects Measurement Component 24.7 mm (0.97 inch) Developer sleeve (Print Cartridge) 26.7 mm (1.05 inches) Charge roller (Print Cartridge) 32.9 mm (1.3 inches) RS roller 37.7 mm (1.48 inches) Transfer roller (ETB) 54.5 mm (2.15 inches) ETB rollers (ETB) 56.6 mm (2.22 inches) Fuser sleeve (Fusing Assembly) 62.8 mm (2.47 inches) Pressure roller (Fusing Assembly) 75.4 mm (2.97 inches) OPC (Print Cartridge)
Jan 13, 2011 | HP Color LaserJet 2600n Printer
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
Printing Problem
Image defects on LJ printers are usually the toner cart. or the fuser:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the image Defect on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 17, 2009 | HP LaserJet 4250n Printer
I am getting a faint line all down the page
Most likely you have a defective black toner cartridge. Open the front shutter on the black toner and look at the drum. If you see the drum has toner on it corresponding to the line down the page, you found the problem. If you can't see anything on the drum try printing a page and then interrupting the printout while the page is still in the printer. If you see the line on the page before it goes through the fuser, (the last roller thing on the top of the printer) then it still is the toner cartridge. If it occurs only after the fuser then it, the fuser, is at fault.
Jun 29, 2008 | HP Color LaserJet 2600n Printer
HP Color Laser Jet 1600 Problem
Hey I have 1 problem I have the printer of 2600n when i give print Command of RED Colour its come orange and right side i get light print and left side i get little dark print , what is the problem i don't understand any can help me . Thank u Morgan.M
Dec 12, 2007 | HP Color LaserJet 2600n Printer
Printing result pour
Is the cartridge gen HP cause this will most likely be your problem if not slight slight chance it could be fuser but I would recomment replace toner/drum cartridge
Dec 01, 2007 | HP LaserJet 4 plus Printer
481 people viewed this question
jasbo
jasbo
