Question about Sony PlayStation 2 (PS2) Console
PS2 disc reading
Certain games on my PS2 won't play, either saying loading for ever or just a blank screen. I don't think its the discs as one is brand new. I've tried a cleaning disc but no change. Any ideas?
  • jao_mae Nov 15, 2008
    some games dont run on my slim ps2. i dont think its the cd's coz they play on my friends ps2.
    Problem Solver:
  • 15 Answers
Use a q-tip and rubbing alcohol to clean the lens.if you don't have a slim ps2 that will involve opening the ps2.it's not that hard really,works every time.
Posted on Nov 14, 2008
SOURCE:
My ps2 is makeing a werd sound when reading dice
It's not able read the disc - try cleaning the disc, try another disc, etc to narrow down the problem. If it won't play any discs either the lens is dirty or an actual hardware failure in the unit.
Jul 23, 2012 | Sony PlayStation 2 (PS2) Console
I want to play duplicate dvds on my ps2 but i am not able to do what should i do can i do it at home
  1. If you have backed up a game for ps2, you're going to need a mod chip or swap magic for your ps2 so it can read the disc, so first things first, BUY A MODIFICATION TOOL!!!
  2. 2You should try using Swap Magic, because it's the easiest, and you won't need to modify your PlayStation too much.
  3. 3But if you use SWAP MAGIC, you will also need a special mod chip, SLIDE TOOL, or a FLIP TOP COVER, you can learn more about those on the swapmagic website
  4. 4Read directions on the installation of mod chip, and swap magic before you do anything (you don't want to mess up, or else your ps2 won't work properly).
  5. 5Install your modchip/flip top cover/slide tool. (This is important, because it allows the disc to be removed and "swapped" without the PlayStation knowing).
  6. 6Follow directions that came with your swap magic discs, and you're basically ready to go!
  7. 7HOW TO USE SWAP MAGIC,Note you must have Swap magic 3.6 to boot on slimline ps2 and you need to do a none solder modding(no soldering)
Purchase a flip top (recommended). Let's assume you have the flip top and a copied ps2 game
  1. 1Now Insert the swap magic disc into the ps2,
  2. 2Press power on button until screens comes up.
    • With option that says load cd open the top cover of the flip top.
    • And take out the cd when it stops spinning.
  3. 3Now insert your Copied game and click Load CD.
  4. 4its that easy
May 30, 2011 | Video Game Consoles & Games
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Wont load
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty.
If your PS2 can not play certain games like Rock band try this tip:
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  5. New screen will appear like
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
And after that wait till your game is loaded.
Click here to view full tip.
Nov 16, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 wont play games
That is a common problem with some ps2s some do it and some don’t just certain ps2 will only play certain games sorry I know this probably doesn’t help just some info
Mar 28, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error frequently with certain games
Just a disc error, the disc may look fine but it maye of been copyed in correctly im affraid, just take it back for a exchange
thanks
Feb 21, 2009 | Sony PlayStation 2 (PS2) Console
Problem with my slim playstation
Replace your laser is a common problem for ps2.They have alot issue about readung disk and if you have aold ps2 try to adjust the lens.Look also for ps2 repair tutorial.
Good luck
May 22, 2008 | Sony PlayStation 2 Slimline Console
Formatting
By formatting a disk, your actually creating a Blank-Disk.
The PS2 won,t read a blank disk.
is your console Saying " disk format Unknown "
This is a completely different Issue.
In this case, the PS2 does not play this type of Disk.
Mike @ compurepair.
Mar 14, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Loading & Playing
change you'r ps2 lence ribon.-goodguy electronics-sri lanka -094785180737-
Aug 20, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
267 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
