Question about Keurig B50 Coffee Maker
Water in Keurig single cup coffeemaker was very low--started it too soon & ran out; added water but still won't flow more than a drip or two
    Problem Solver:
  • 11 Answers
Make sure there is water before you do all this. Unplug it from power wait 1 minute plug it back in. Open and close the coffee holder, wait a few seconds, press any of the brewers. Basically reset the whole system.
Posted on Dec 07, 2008
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Starts running water when I turn it on, and won't stop
Did you do the unplug, take off reservoir turn upside down and shake a little? It has worked for others.
Here is video of troubleshooting with added upside down theory. Fix Your Broken Keurig Coffee Maker New tips and tricks Water Flow Issues
Nov 28, 2015 | Keurig Vue Brewer V500 Single Cup Home...
I put milk in my Keurig and now it won't work...i think the milk burned
..wait..you mean you poured actual milk into the water reservoir on a Keurig coffeemaker..?
That's not good.
What prompted you to do that?
My advise would be to boil water in a kettle, adding about a half-cup of regular vinegar. Pour this into the coffeemaker and let it run through a cycle with just the hot water/vinegar solution. Next, run plain hot water through it.
Hopefully, this will help with flushing out any/all milk that's clogging the coffeemaker. You may have to do this several times to remove the milk residue..milk will cling. (and will start to smell foul..which may or may/not attract insects) so don't ever do that again!
Phoning Keurig Customer and product support may assist you further. They are generally very helpful with all inquiries and issues.
Keurig single-cup coffeemaker
http://www.keurig.com
(866) 901-BREW (2739)
Jul 12, 2012 | Keurig B30 Mini Coffee Maker
"Prime" is showing in the upper right corner of
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 10, 2011 | Keurig B60 Coffee Maker
Cusinart coffee pot single serve with kuerig cups switch won't turn on
The problem is often that the machine develops a leak in the hose that is right over the transformer...the water drips onto the transformer and kills that... then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig One Cup Coffee Brewer will not turn on
heatman101
Sep 01, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Mar 25, 2010 | Keurig B60 Coffee Maker
I have a Keurig B60 coffeemaker. When making a
Descale yes you should every 3 months. Use 48 oz. of white destilled vinager and follow the instructions in your use and care guide
Mar 14, 2010 | Keurig B60 Coffee Maker
Keurig B60 coffeemaker stopped pumping water because I didn't notice there was almost no water left in the chamber and started it--I added water right away but it won't pump any more water out of the...
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Nov 11, 2008 | Keurig B60 Coffee Maker
Keurig B50 Coffee Maker Logo
116 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
