Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
Washer Dishwasher fills with water, wash cycle does not start up. The machine continues to go thru the wash, rinse, cycle, discarding water, filling again, etc. but no water sprays in the machine, Thanks for any help !
  • 2 more comments
  • Tony Giov Nov 22, 2006
    Still need help with this one...... ! Anyone with a solution ? The sprayers won't spray !
  • hart999 Jan 03, 2008
    Dishwasher drains then enters wash cycle but no pressure on water from jets. Some flow during rise, but again no pressure evident. Detergent is dispensing but not disolving (no water pressure). Some water remains in bottom at end of cycle...but drains when next cycle initiated. Tank overflow switches seem to work.
    Suspect circulation pump is shot...8 year old dishwasher. Viking VUD141
  • Anonymous Mar 20, 2014
    wash cycle starts the bottom fills with water then stops,when starting over the water empties out then stops
  • Anonymous Mar 25, 2014
    when on it doesnt fill up with water on wash cycle
  • 175 Answers
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Posted on Nov 23, 2006
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    No water during any cycle.
    if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
    Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
    The washer doesn't always fill up when we turn it on
    Hi, Dose the water fill the first time you start it but, then will not fill in the rinse cycle? Does the water continually try to fill but never gets to the top?
    I want to help.
    Thanks
    Vic
    May 12, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
    Rinse water barely trickles out of my washer
    Do you fill the machine with hot water only?
    If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
    When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
    When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
    Apr 29, 2009 | Washing Machines
    We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
    The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
    Mar 13, 2009 | Washing Machines
    Cold water will not stop filling during rinse
    while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
    Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Basin will not fill with water during rinse cycle but will agitate and spin.
    most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
    Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
    555 people viewed this question
    Top Viking Dishwashers Experts
    Craig Butler
    Craig Butler
    Mike
    DADA BHAI THAKUR
    DADA BHAI THAKUR
    Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
