Question about Archos Audio Players & Recorders
My laptop no longer recognises my archos 105. i connect the usb but it keeps on saying connect device, and when i press refresh device it doesn't come up with my MP3. HELP!
  • 1,879 Answers
Try another USB cable and USB port
Go to Device Manager and Uninstall Archos Device Driver
laptop no longer recognizes the device = communication problem
Posted on Nov 11, 2008
    Brigadier General:
  • 6,966 Answers
Initially, it is possible that the issue is with the USB ports of the laptop. A couple of ideas you may wish to explore/check:
  • have you tried any other USB devices such as a digicam or printer on the USB port of the laptop;
  • was there any recent updates of your OS;
  • incidentally, what is your Operating System pls;
  • have you tried verifying that there are no errors in your USB devices inside the Device Manager;
  • have you tried deleting the all USb instances inside the Devie Manager, rebooting and allowing the laptop to re-install New Hardware found;
  • have you tried updating the USB drivers from the laptop manufactures support/download pages?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
  • Archos Master
  • 13,433 Answers
Try the archos on another computer, see what happens does it work there? Is it saying connect device on the screen of the archos? can it be used? any other complaints - does the unit complain? errors? error code?
Archos 2 OC won't charge and is not recognised by laptop
Sometimes with mp3 players the cable is the one that is mostly damaged. Try replacing this cable and try again. It actually has happened to me on two different mp3 players. Cables are always faulty.
Jul 12, 2012 | Archos 2 (8 GB) MP3 Player
CProblems onnecting Archos 700 after connecting 605 to PC
It is very possible the drivers conflict. You should try uninstalling everything to do with the one you don't want. Then install the drivers/software for the 700. Also what software are you using and what version?
Thanks,
Lee
Sep 21, 2008 | Archos AV700 Digital Media Player
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Archos won't connect by USB to computers
You should keep your eye on the device after its been plugged to the PC it will give you 2 options "charge" or "usb" you ca not establish a connection without picking usb connection option on the Archos screen when it pops up. If you are doing so and problem still existed then i would recommend you to download the latest windows media player. Because it comes with new devices sync driver update.
Aug 10, 2009 | Archos 605 Wifi Portable Multimedia Player
Archos 605 running Vista Computer does not recognise the archose
Go to settings and look under system.Then look where it says usb peference then see if it says windows media device if not change it to this and if that doesnt work try the other settings.If that doesnt work go to Archos.com and contact them and see what they can do.
Feb 06, 2009 | Archos 605 WiFi Digital Media Player
Archos pma 400 usb device does not recognise
Device drivers are not loaded or not loadwed properly.uninstall them and go to the web site and download new drivers.they should then recognize the player.RICHARDM69
Dec 17, 2008 | Archos PMA 400 (30 GB) Digital Media...
Can't link my archos to my laptop
1. Copy all factory installed files from the Archos on to your PC hard drive or write a CD / DVD.
2. Download the latest software from www.Archos.com and keep a copy safe (not on the Archos!) … there was a new version last week by the way …1.5.12
3. If you record any films, music, or TV that you want to keep forever then don’t keep them on the Archos!
4. Factory installed samples (photos & films), wallpaper, etc are available for download from FTP://support.archos.com
5. If you need to format the drive but it won’t talk to the PC through the normal USB, try plugging a flash memory card (the bigger the better) into the other (left hand) USB socket and copy stuff onto it.
6. Avoid changing back & forward between ‘hard drive’ and ‘windows device’ … not sure if this was the cause of the problem but you never know!
7.Always have mains power (not battery) when moving files around.
Nov 13, 2008 | Audio Players & Recorders
Not recognised under USB
if you are having technical problem with your archos 605 just do this connect your USB with your computer and your archos device will pop up on the screen asking you if you want to charge your device or enaable usb that will automatically appear if your computer doesen't reconise the device then switch it off and on again if doesen't work then i suggest you look it up on the archos manual which is located on your device. if that doent work then i think you may need to update your computer it must have windows Core dual processor if that don't work and your archos device doesent appear then i think you may need to update your computer with a service pack 2 installation cd
Oct 01, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 usb connection problem
its possible you could have picked up a virus that is making unauthorized changes to your pc. happened to me. had to reboot pc to original factory settings.
Jan 27, 2008 | Archos 605 WiFi Digital Media Player
Archos not recognised by both my computers
You must update the firmware on the archos.
Dec 07, 2007 | Archos 605 Digital Media Player
42 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
