Question about Mitsubishi VS-45607 45" Rear Projection Television
Intermittent vertical jitter.
Picture jumps vertically at a rapid rate. Looks as if the vertical sync pulse is somehow being affected. Sometimes the picture will lock in by turning the set off and back on. If the set is unplugged from the power source, it will play normal for awhile, the the problem will return. Sometimes it will play for hours before it begins to jitter. Pressing the PIP function on the remote will cause the problem to occur immediately. So far, I have resoldered the joints on the vertical IC (IC-451) and around the vertical section, as well as the power supply section and horizontal section. I have replaced all the electrolytics in the vertical section as well. Problem still persists. Any help will be greatly appreciated. Thanks, Proton1000
    Problem Solver:
  • 10 Answers
These sets have a PIP module which is plugged into main board and has a brown ground wire to the can.Surface mount caps c7001 and c7036 are usually the problem but if the capacitors have leaked too much you may never recover the board,CURE eliminate PIP by putting 10 mfd 50v cap from pin 5 to 11 and another from pin 9 to 7 on the VP plug under the main PCB
Posted on Nov 09, 2006
SOURCE:
Mitsubishi VS-55609 top left screen has folded over
chk for any electricity or magnetic interferanc. change the location to the TV. switch of the tv fro 5 min and restart it again back.
Jul 03, 2008 | Mitsubishi VS-55609 55" Rear Projection...
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
I have a vertical line in the middle of the tv it has what looks like pictures how do I resolve this at home
hi there, seems you have a defective Vertical IC. If you can locate this 8-10 pins mounted on heat sink and has label LA 7837 or alike. try to replace this. defective vertical IC somehow manifest as horizontal line in the middle of the screen. it has picture but cannot adjusted to occupy the whole screen. Hope this help, please rate and vote. good day
Mar 26, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Picture looks like it is jumping
Sounds like a vertical sync issue on the chassis board. However you also mentioned the picture moves left to right or vice versa which would suggest a horizontal sync issue. Either issue is not repairable by the DIY. Sync issues must be isolated using test equipment usually found in repair shops. My suggestion push it down a hill and enjoy the show then go buy that flat screen you almost purchased last week.
Jul 25, 2009 | Toshiba 42H81 42" Rear Projection...
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Feb 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Intermittent vertical jitter on mistubishi tv 65000
Good Day, sdkhanmd; Replace C2P05 100 UFD 16 VOLT off pin 3 IC2P01 and IC2P01 part #270P466020 (9 volt regulator). Both are on the signal PCB. Also, check other caps in area for leakage. Hope this was helpful, this common for this model. Good Luck, big IRISH.
Jul 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vertical Hold doesn't Hold
This would denote some kind of vertical sync problem. I would begin by checking the vert sync circuitry. To do this you will have to have an Oscilloscope, and DVD containing a steady-state picture. The oscilloscope is used to measure the vertical sync rate and the vertical sync pulses. Taking into mind that ther is a video signal present but it is in the black range. If you do not have an oscilloscope it makes troubleshooting this hard. in any event you will also need a schematic to see what waveforms you should be seeing. If you do not have a background in electronics you may have to have someone who does look at this unit.
Sep 19, 2007 | Rosen CV1010N Car Monitor
Mitsubishi Model # VS-7085
It sounds like vertical jitters:INSTALL VERTICAL JITTER KIT, PART # KIT-V14VJ . If it gets bright and shutdown then:. CHECK THE VALUE OF R9A45 (180 OHM 1/2W RES.),IF OPEN OR INCREASED IN VALUE CHECK FOR A LEAKY OR SHORTED C9A57 (1UF 350V).AT THE CATHODE OF D9A07,ON THE MAIN-PCB.
Sep 05, 2007 | Mitsubishi VS-7085 70" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
136 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
