Question about 3M X75 Multimedia Projector
Dukane 8010 imagepro
My projector which I just bought used from ebay. The bottom of the image is just light. Any ideas of how I can fix please help.
I have a Dukane Projector and each morning my power light is solid red (no other lights are on). I have to unplug it and plug it back in and then everything works fine until the next day when it happe
Hello Bucky
Red power LED without any other LEDs usually indicates a power issue with incoming power or with the projectors circuit power supply. You should try a different power source first.
Ernie
Dukane A/V Service dept.
Jan 14, 2015 | Dukane IMAGEPRO 8942 Multimedia Projector
Dukane imagepro 8778 does not power on.
if there are any indicator lights on the projector?
Feb 10, 2014 | Dukane ImagePro 8778
Can I view a DVD movie using the projector and if so, how do I set it up?
connect a dvd player to the appropriate input connector. depends on what type of outputs the dvd has available, composite or HDMI or component
May 21, 2011 | Dukane ImagePro 7100HC Multimedia...
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
LCD projector still not working after lamp change
Sounds like you have a faulty ballast. I recomend changing it. This is your lamps own power supply.
Apr 10, 2009 | Hitachi CP-X250W Multimedia Projector
Pixels appear shifted or smeared
I'm looking at the specs for yu projector right now.
Native resolution = 800 x 600
Maximum resolution = 1280 x 1024
The problem you describe can occur when you run a hi-res signal over 1280- x 1024 into your Dukane projector.
You say that this problem is there, whether projecting a computer image or not.
I have two thoughts.
(1) You have suffered one or more LCD panel failures.
(2) The combining prism in your optical block has come loose.
In either case, there is no simple repair that you can do yourself, and looking at the age & low-specs of the machine, don't put a single dime into repairing the machine.
Mar 31, 2009 | Dukane ImagePro 8039B LCD Projector...
Dukane image pro 8800 reset lamp timer
Reset Timer
1 Slide Cover on remote down
2 Hold timer button 5 seconds
3 Toggle to right - 0 CANCEL toggle back right to 0
Jun 11, 2008 | Dukane IMAGEPRO 8942 Multimedia Projector
Focus
if the focus motor does not work, the motor could be bad. or because it is an lcd projector, it could be the fly-eye lens or the light filter is singed and need replacing. also try matching resolution with source.
Nov 07, 2007 | Dukane IMAGEPRO 8942 Multimedia Projector
3M X75 Multimedia Projector Logo
Top 3M Office Equipment & Supplies Experts
ray gallant
Tom Chichester
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
