Question about Polycom SoundPoint IP 501 IP Phone
Making a Polycom SoundPoint 501 work on an Avaya IPO
I am trying to make a Polycom SoundPoint 501 work connecting with an Avaya IP Office using SIP Trunk license. I got the phone to call into the system and ring extensions, but I have no audio path. Help?
As you have probably found, SIP phones are not supported until R5, which just came out.
Posted on Sep 27, 2009
Polcom phones stop ringing
go to this website and go to customer support www.polycom.com
Jun 24, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom 501 phone keeps trying to reboot itself. We rebooted manually a few times and get the same error message: 'Could not find boot server current configuation" Any ideas?
try to turn off the Polycom device. When you turn it back on, press Setup. from the options, select server then click edit. Then select the item Trivial FTP (that setup depends on your ISP), and type the IP address assigned to your network (example 192.168.90.90) then hit OK. click exit several times then press Save & reboot. If it did not work, let us know...
Jun 19, 2010 | Polycom SoundPoint IP 320 SIP IP Phone
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
Connection Problem
I think you have to have the upgraded cable modem with the rj11 on the back in order to pull the voip dialtone. Hope this helps
May 14, 2009 | Polycom SoundPoint IP 501 IP Phone
PLANTRONICS Headphone won't work with IP 501 sip, polycome phone
Dont plugged into the headset jack. Like Nortel, connect headset line with phone base unit in receiver jack and plugged your phone receiver wire into headset or plantronic base unit. This will work. I am sorry, my english is not too good but hope you understand it now. But the pully is not working properly with IP501..I mean it is not good to pickup IP501 receiver and put it back right place.
Dec 17, 2008 | Polycom SOUNDPOINT IP 501 SIP
Polycom ip501f error, application is not present
Make sure you have the latest BootROM and SIP config files for this polycom(sip.ld, sip.cfg, etc...) on your TFTP server. If you do not have this - download from here - http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip501.html
If you do not have a TFTP server, you can download one for free.
Dec 04, 2008 | Polycom SoundPoint IP 501 IP Phone
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 28, 2008 | Polycom SoundPoint 330 IP Phone
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
I have 13 soundpoint ip 501 phones
R U USING XLITE OR ARE YOU USING ANY ASTRISK SEREVER... IT IS VERY EASY JUST GIVE ME THE INFORMATION..
Dec 05, 2007 | Polycom SOUNDPOINT IP 501 SIP
Polycom SoundPoint IP 501 IP Phone Logo
387 people viewed this question
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Darren  Means
Darren Means
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
