Question about HP Officejet 4315v All-In-One InkJet Printer
Refilling my #22 hp tricolor cartage
I want to refill my cartridge but I don't know which hole is what color. The black I believe is easy if I remember correctly but the tri-color I had problems with before so I just got a new one. but right now I am disable and not able to pay that much so I'd like to refill the cartridge. Now your link says"All-in-One Inkjet Printer" On my printer it just says " "All-in-One" it doesn't say "Inkjet" if that matters it is a printer/fax/scanner/copier. I'm pretty new to all this, as you probably can tell.
I appreciate any help you can give.
  • comfortsspir Nov 19, 2008
    Thanks for trying but we don't have walgreens. I live aprox 50 from one.i am wanting to refill the cartridge I have with the universal kit I have. I just don't have the instructions or know which color goes in what hole
Have u tried going to Walgreen's? They refill color cartridge's for $15 sometimes they even have a buy one get free sale which means you pay to get one cartridge filled and they will fill the other one for free. Or check on ebay sometimes they have HP cartridges cheap.. Hope that helps..
Posted on Nov 17, 2008
Refilling procedure
You need to specify what brand is your printer.But the procedure is as simple as dirty. Make sure you have a cloth or paper to handle the messy part :).
Requirements: 1. Printer-Ink 2. Syringe with thin needle3. Piece of cloth
I will write how to refill HP cartridge, because I don't know your model.Ususally Hp cartridges have colored or black spot ont white sticker.Under this spot there is a tiny hole. This hole is designed to be used for refilling. You need to pierce the spot with the needle and start the refilling process.Make sure that there are no bubbles in the syringe and start filling slowly the cartridge. Do not hurry! Don't fill the cartridge to its full capacity. If your cartridge is 20ml fill only 15 or 16ml.After you finish set aside the cartridge for 30 minutes so that the ink settle. This is it!Good luck!
Dec 19, 2011 | Office Equipment & Supplies
I don't know how to refill?
Refilling HP color printer ink cartridges saves money and time spent running to the store to find the right ink cartridge, which sometimes is out of stock. By having the refill kits for the HP ink cartridge, you can just refill the cartridge when the ink runs out. The refilling process is easy to do and anyone can do it in a few minutes. The ink kits come with directions and all the colors one will need to refill the ink cartridge.
1.Place a piece of paper towel on a flat surface. Remove the empty ink cartridge from the printer. To do this, open the cover and wait for the ink dispenser to move the ink to the open door. Lift up the tap that holds the ink cartridge in place and pull out the cartridge. Push the tap holder back down and close the cover.
2.Place the ink cartridge on the paper towel. Gather the ink refilling kit together with directions and place the ink jars on the paper towel along with the syringe needle.
3.Find the indents on the top of the empty ink cartridge. Poke these holes open with the pen. Sit the cartridge down and open the ink containers. The colors are yellow, cyan and magenta.
4.Read the directions to see where each color goes in the ink cartridge. Insert the syringe needle into the ink container and raise the stopper up until you have the recommended amount of ink to fill into the particular hole.
5.Insert the needle into the hole on the ink cartridge and slowly dispense it into the cartridge. Remember to go slow with this step. If you see the ink oozing out, stop filling and wipe with a paper towel.
6.Cover the holes with the tabs that come in the refill kit or you can use tape. Make sure the hole is sealed to prevent spilling or the ink drying up. Then replace the ink cartridge back into the holder in the printer.
I hope you find it very helpful. Thank you for using fixya.
Aug 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
Jun 01, 2009 | HP DeskJet F4280 All In One Printer InkJet
Want to refill hp tricolor 22 but don't have instructions
check here http://www.youtube.com/watch?v=II9gpIXs_lE
but be cure full you need to remove air bubbles after refilling
Mar 17, 2009 | HP DeskJet F380 All-In-One Printer
Check print cartridge error
Set the properties to print on HP paper. This usually solves the problems
Mar 09, 2009 | HP DeskJet 3745 Printer
How to refill hp 818 inkjet cartridge
on 818 hp cartridge five holes are there, which colour ink on which hole i have to put ink on them
Dec 03, 2008 | HP DeskJet F380 All-In-One Printer
Cartridge error, caution this machine could work at any time
This does not look like a chip issue (as i can tell from
http://www.inkfilling.com/inkjet-cartridge-hp-22.html )
Every now and then you will need a new cartridge you cannot
refill the same one forever it will go bad, perhaps this is the issue.
Some more info/possibilities at http://www.inktelligent.com/topic_382.html
Oct 27, 2008 | HP Officejet 4315 All-in-One Printer
Try pushing it gently using some pressure. I had the same problem and it got solved using a little push.
Aug 27, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Officejet 4315v All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
