Question about ASUS P4P800-VM Motherboard
Power led connector problem
I have an old Asus motherboard p4p800-vm i have problem to connect the power led.
Some body help me please. thanks.
    Sergeant:
  • 207 Answers
[ 1] [ 2] [ 3] [ 4] [ 5][ 6][ 7][ 8][ 9][10]
[11][12][13][14][15]16][17][18[19][20]
Robert,
Above is a rough diagram of the Front panel connector on your Motherboard. Your Power LED should connect to pins 1 & 3 if this connection does not have the power LED come on with the PC then reverse which wire you've attached to those two pins. (As LED's are polarized they must have current flow in one particular direction to operate) Pins 11 & 12 are your Hard drive activity connector
Hope this helps you
Dave
Posted on Nov 11, 2008
    New Friend:
Panel phptos
Posted on Jan 01, 2013
I have a asus p4p800-vm motherboard I have everthing hooked up right the front panel wires power from the processor and power supply led lights hdd reset everthing but when I plug the computer up nothing...
Hi, maybe you should download a manual.
From here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800VM/#download
Just to check you have connected everything right.
First select your operating system.
Select manual and click on global for download.
The file has to be unziped before you can read it.
Have you installed the ram module and cpu correct ??
If you have installed a wrong type of ram it will not boot at all.
Does it makes any beep sound ??
Is the powersupply ok ??
If you are useing the onboard graphic check for loose connections.
Check with the manual that all connections are in order.
Aug 28, 2011 | ASUS P4P800-VM Motherboard
What is a serial port and where is it on the p67 mb
a serial port is a 9 pin (DB-9) connector for serial communication (RS232) used by modems, mouse, etc... In older machines you had a DB-25 (25 pin connector) as well usually situated in the back of the computer near the printer port (DB-25 connector) but femail (25 holes insdead of 25 pins)
Hope this helps!
Aug 06, 2011 | ASUS P4P800-VM Motherboard
What is the best power supply for asus p4p800-vm or suetable power supply
A good brand P4 Power Supply (24-Pin) of 350-450 Watts is generally used and sufficient for it.
Hope it helps! Good Luck!
CreativeTECH
Apr 26, 2011 | ASUS P4P800-X Pentium Motherboard
Asus P4P800-VM , Audio, Video, LAN)
You didn't mention your Operating system version and bits. I am providing Windows XP 64 Bits drivers below.
Audio:
http://dlcdnet.asus.com/pub/ASUS/misc/audio/ad1980/AD1980WHQL.zip
VGA:
http://dlcdnet.asus.com/pub/ASUS/misc/vga/springdale/sdg3845_2kxp.zip
LAN:
http://dlcdnet.asus.com/pub/ASUS/lan/PRO100/80_2kxp.zip
For more assistance please stay connected with us.
Thanks for joining Fixya. Have a nice day.
Feb 23, 2011 | ASUS P4P800- VM 865G UATX P4 AUDIO VIDEO...
Front panel power switch & led'S pinout
asus web site download manual for a p5pe-vm thats all you need
Apr 30, 2010 | ASUS P5PE-VM Motherboard
Where can i find the ethernet driver for p4p800-vm/s??? please help!!!
http://support.asus.com/download/download.aspx?model=P4P800-VM&SLanguage=en-us
Jan 11, 2010 | ASUS P4P800-VM Motherboard
I need a diagram showing placement for the case power switches
The manual for your MB is available at the ASUS website, as a PDF file. This is a direct link to the manual:
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
The info you need is located on page 1-28 and 1-29 of the manual.
Cheers
Nick
Dec 01, 2008 | ASUS 865G (MBAS-P4P800VM) Motherboard
Front panel connectors
hi im wesley. ok the power and audio connecters is very simple if you look at the bottom right of the motherboard you will see you can plud them and it says the name of witch is the power and witch is audio and it doesnt realy make a difference witch way you put them in just as long as they are on the right pins. the usb might be a little more tricky unless it says witch connecter is the usb 1&2 then its the same as the power led but if you dont come right i will try to get a diagram for you or draw one up but it might not be as accurate tho as i do not own a asus motherboard but i will do my best.
Jul 11, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
ASUS P4P800-VM Motherboard Logo
361 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
