TVM 1900c Sansui, no picture but has sound started at line in the middle
Can you help me fix this problem, It started one day when I was watching and
suddenlly I just see line in the middle but I can hear sound. What do you think the wrong componemt maybe
  • Anonymous Nov 12, 2008
    middle problem. I cleaned it (vacuum) and it worked after a while the picture goes out again, I turned it off, and few minutes after turned it back on and worked again
    So it seems to do this after it gets warm...
    Description:
  • 790 Answers
Hi
you have defective vertical output! that is vertical IC and 1.2 Ohms Resistor.. replaced the two components..
Thanks!
Posted on Nov 12, 2008
Yesterday my sansui was not showing any picture although it was on,the screen was cold. today the power button does not turn on.
Sansui HDLCD3700 -- Turns On, No Picture/Sound - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
May 20, 2013 - 7 posts - ‎3 authors
Sansui HDLCD3700 -- Turns On, No Picture/Sound ... My Country: USA ... not been able to get any sound or video at all (no backlight either).
Sansui hdlcd185w repair - YouTube
? 2:25
https://www.youtube.com/watch?v=qMpiC8YL3SE
May 31, 2013 - Uploaded by After Hours Tv & Pc repair
Thanks so much for posting, saved my kitchen tv from the landfill!... Also the buttons on the side of the tv do not work correctly. ...Any suggestions? .... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW - Duration: 5:29 ...
Jan 08, 2016 | Sansui Televison & Video
I have a 42 inch plasma sansui for 3 yrs now and just recently a black line appear in the middle of the tv almost like separating the picture in 2. what could be the cause of this can it be fixed or has it...
I dont believe it could be anything to do with the remote. It sounds to me like some thing is wrong with the line producer. If i was you i would take it to my local TV repair man. It maybe some thing simple.
I hope this helps.
Apr 08, 2011 | Sansui Televison & Video
Hi there My Sansui TV screen started showing thin white horizontal lines across the top of the screen. All of a sudden the screen starts condensing the picture into fine lines across the middle of the...
It is an indication that you have a problem on the vertical section on the main board. The faulty parts is the electrolytic capacitor which affect the linearity of the screen that's why you encountered that kind of problem.
I've advice you to send it to repair shop or look for a qualified technician to isolate the faulty electrolytic capacitor and do re-soldering for some dry joints on the main board.Once replaced the capacitor your unit will back to normal again.
thanks for using fixya...
Jan 07, 2011 | Sansui TVS2750 27"
Straight line in the middle of monitor. picture srunct
This is called vertical collapse and the most common cause is a failure of the vertical IC. If you can update this with the model number, I should be able to provide the part numbers and costs for the parts required to fix this. Also, if you intend to repair this yourself, please indicate thtat as well. The parts will cost around $20 or so.
Dan
Dec 08, 2009 | Sansui 27" TV
Sansui LCT37SD switches off by itself
To anybody that has not been able to solve problems with the sansui lcd tv ,lines ,dots on screen etc after warming up ,pls contact me for the solution to the problem. i have succesfully repaired my lct 37st for next to nothing. garth@cybersmart.co.za
Apr 13, 2009 | Sansui HDLCD3210 32 in. LCD TV
Tv problem
It sounds like the H.O.t shorted out I would start there, or it's the flyback.
The TV went into shutdown to protec it self from more damage.
Nov 11, 2008 | Televison & Video
No picture
hi, the problem is in the vertical ossilation.. let me know
Dec 18, 2007 | Sansui DTV2760 27" TV
Problem with tv
Its known as 'screen collapse' and yes it can be fixed but it may not be economical you should get some quotes from your local tv repairers.
Nov 14, 2007 | Televison & Video
Line in the middle of screen
You have a bad component in the vertical circuit of your set. If you hit it on the back of the cabinet with your hand which will "jar it" and the picture flashes back on then you have loose connection. If nothing happens then the vertical circuit has a bad component most likely the Output IC. (Chip) Stargazer
Mar 27, 2007 | SansuiS2001 20" TV
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
