Question about Bosch Axxis WFL 2060 Front Load Washer
My bosch WFL 2060 Front Loader Washing machine stops mid-way ..
Its program- can you advise me what to do?
    Scholar:
  • 97 Answers
Hiya
i'll need a little more info if you can, like what exactly does the machine do or not do?
does it make any strange noises?
does it trip out the electics?
the more you can answer for me the better the diagnoses
thanks kj
Posted on Nov 11, 2008
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Just bought the Bosche Axxis front loader. When the spin cycle kicks in, the machine wobbles/shakes/wanders VIOLENTLY from side to side. Is it the installation or the machine?
I bought the Bosch 8Kg washing machine on 8th Feb, I had the same problem.
Read installation instructions, you need to remove transport safety nuts from the back.
Feb 06, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Mould inside rubber seal
Bosch Axxis WFL 2060 Front Load Washer mould on door
gasket.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Bosch Axxis WFL 2060 Front Load Washer
The drum stopped turnig and there seewms to be no life in the motor on our BOSCH Maxx WFL 2060 does any one have any idears. Thanks
you need to test the motor to see if voltage is getting to it.. if yes change brushes or motor complete...01179512835
Dec 30, 2009 | Bosch Axxis WFL 2060 Front Load Washer
How do I winterize bosch front loader washing machine
Turn off the water supply to the washer, and disconnect the inlet hoses, remove the drain outlet hose and lay it down to drain any water in the hose.
Remove filter, and drain water off inside.
That should do it.
Hope this helps.
Dec 10, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Jul 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
178 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
