Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 frozen
It is on 58 mins, the time is flashing and it sounds like it is draining. I have unplugged it, but when i plug it in, it is the same
  • Anonymous Nov 23, 2008
    During each cycle the machine stops working and starts beeping. The time indicator is flashing F then H alternately. I can restart by pushing pause and then the start button, but this gets to be a pain at each step in the process. Help please
    Problem Solver:
  • 3 Answers
F H is a problem with the water fill could be water pressur is low?
Posted on Dec 01, 2008
Wont drain with a load, but will drain when empty. Have cleaned filter, have run drain cycle with filter open motors works. have filled using start of 32 min cycle, and emptied using drain, at l
sounds like inside the drum a dog waste bag or a small plastic bag for something plastic has melted onto the heating element
this can be removed for checking not easy bit fiddly but at least you can rule it out
ah you think i didnt have plastic in my wash
got kids?? then the soap drawer is the place all dirty things go to get washed
sounds like some plastic flapping about above the drum drain port
Nov 28, 2014 | Candy Washing Machines
Washing does not go through the drain cycle, All lights flashing, cycle does not complete
Several issues could cause this, and if all lights are flashing could indicate a issue with the motherboard or that its trying to flash a mechanical code, depending on the exact model. Best reconmendation is to unplug the machine for 2 to 3 mins giving it enough time to reset. Also check the drain hose for clogs and if mechanically incline, go ahead and open the back service panel or font panel and service the pump. Possibly sounds like a draining issue which could cause this as when the water goes through the pump and if its not exiting the machine at a certain speed can send a signal to the board to shut down and flash codes.
Draketech
Oct 14, 2010 | Kenmore 44102 Front Load Washer
Machine wont drain
What you need to do is unplug unit for 30 mins, plug back in and try again
Jan 20, 2010 | Washing Machines
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Wii Console stopped working
I unplugged the Wii system for about 15 min then turned it on and it works fine
Jun 16, 2009 | Nintendo Wii Console
Unplug/protect
The audio amplifiers ICs of your device are damaged.You gotta take it to service center.Good luck.
May 25, 2008 | Sony Dream System DAVDX155 Theater System
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Start Cycle won't start, just flashes
first of all, with any problem, always try to reset it, unplug it for 20-30 mins or so and replug. it sounds to me like The motor is probably froze up. Very common if they sit for any length of time. Easy to fix too. Just get underneath it and look for the blades on the motor shaft. Give them a turn. BE CAREFUL NOT TO TOUCH ANY WIRES though. Unplug it first if you can. good luck.
Mar 27, 2006 | Kenmore 24 in. 16299 Built-in Dishwasher
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
55 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
