Question about Harman Kardon Audio Players & Recorders
My bass box stopped working and is under warranty
  • 624 Answers
You need to take it to an authorized service center, here is a link to Harman Kardon website and you can find one near your home. If you do not do it this way, you will loose your warranty and then must pay for the repair yourself.
You can copy and paste this link into your internet browsers address bar at the top of the browser, then hit "ENTER"
Then you must put the proper information in the boxes to find the right place to take it.
I hope this helps, and a FixYa! rating would be appreciated and appropriate. After all, it is the only reward we get for offering people like yourself this free help.
Let me know if you need any further help from me.
Posted on Nov 11, 2008
07 cadillac cts has no brake light all fuses are good and replace the brake switch.still not working any advice
Stop Lamps
The brake pedal position sensor is a resistive device used to sense the action of the driver's application of the brake pedal. The brake pedal position sensor provides an analog signal that will increase as the brake pedal is pressed.
The brake pedal position sensor receives both a 5-volt reference voltage and a low reference signal from the electronic brake control module (EBCM). When the brake pedal is pressed, a variable signal is applied from the brake pedal position sensor to the EBCM through the brake sensor signal circuit. The fuse block left rear supplies battery positive voltage to the bass relay switch through the BASS fuse. One side of the bass relay coil is permanently grounded at G402. The EBCM supplies voltage to the bass relay coil upon receiving the signal from the brake pedal position sensor. The switch contacts of the bass relay close and battery positive voltage is applied through the bass relay switch to the center high mounted stop lamp (CHMSL), and to the turn signal/hazard flasher module through the stop lamp switch signal circuit. The ground for the CHMSL is applied from G402. The turn signal/hazard flasher module then supplies voltage to the left and right stop lamps in the tail lamp assemblies that have ground at G401 and G402. For export vehicles the stop lamps receive battery positive voltage directly from the bass relay.
Do you know where the rear fuse box is ? Check BAS fuse 15amp. and the bas relay , should be marked on the inside of the fuse box lid . The rear fuse box is located
Fuse Block - Left Rear
In the passenger compartment, under the left side of the rear seat at carpet
Power and Grounding Component Views
Electrical Center Identification Views
Fuse Block - Right Rear
In the passenger compartment, under the right side of the rear seat at carpet.
If fuse and relay are ok your best would be to take to a cadillac dealer .
Jan 19, 2017 | Cadillac Cars & Trucks
Bass sounds are extremely loud and distorted. Do I have to send the set in for repair under the warranty?
If you can't adjust correctly bass, at a comfortable level and without any distortion, for sure you should return it on warranty!
May 04, 2015 | Mackie Onyx 32.4 Premium 32-Channel Analog...
Direct out kills speaker signal on my behringer bx1200
If it's still under warranty, get it replaced. Otherwise, take to an authorized behringer repair shop, or your local pro-audio repair shop.
Apr 12, 2012 | Behringer Ultrabass Bxl450 45w 1x10" Bass...
Only two of my speakers work when i unplug them and place in different parts the actual speakers are fine--how do fix the problem
check all connections, the volume and the manual again. if problem persist and its still under warranty, use it
Oct 18, 2009 | Logitech SoundMan X2 Computer Speakers
One of my pair of mackies has solid bass through higher volumes, but my other attenuates the bass and sounds like its blown past a moderate volume. It did this out of the box
If it is under warranty, make use of the warranty immediately.
If it is out of warranty it comes down to whether you are adept at electronics.
The cause can be a blown speaker, or something electronic.
The electronic cause would LIKELY be a problem with the input filter caps that cause the voltage to "collapse" under higher load OR a bad power amplifier transistor or chip.
In any case, test equipment will be required to solve the problem.
Oct 09, 2009 | Mackie MR5 MR5 Reference Monitor
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
Bass Problem
you may have a short in the wiring
you can always open up the bass box and look to see if the wiring is a little loose.
if you know how to use soldering you may be able to fix it.
if not you may be able to just tape it in place
Apr 29, 2009 | Altec Lansing ADA 885 Computer Speakers
Bass amplifier doesn't work even when i switched the batteries.
The bass unit must be defective. Talk to the guys at Skullcandy for a replacement (they offer lifetime warranties for stuff like this).
Their website has a link directly to the warranty page as well:
Hope this helps
Apr 14, 2009 | Skull Candy Skullcrushers Headset
Hi David
The fault may be the bass driver itself or the Low Frequency power amp built into the speaker box. hard to determine which it is because it is intermittent. There are a couple of things to try. when the fault occurs.
  1. just lightly touch the cone on the bass driver see what happens. If it fires up again, it has failed soldering on the spider wire connections from the terminals to the cone. This can be repaired by a decent sound guy the does speakers, or a specialist near you that can be found easily enough. A new replacement driver is also an immediate option if you don't mind spending the bucks.
  2. if the above didn't work, to prove to yourself where the problem may lay, you could swap the bass drivers from one box to the other and see if the fault follows the driver, or remains with the speaker box. If the electronics are faulty, unless you have some decent experience with soldering and fault finding, you may be best to get it to a repair guy,
If you cant get it sorted, please provide me with your location(not address:)) and I will be able to locate a decent guy that knows what he is doing for you. Cheers
Sep 04, 2008 | M-Audio Studiophile BX8a Speaker
Just stopped playing
is it a seald box or a ported box?
Oct 23, 2007 | Jl Audio 12W7 Car Subwoofer
98 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
