Question about Victory Freezers
Replacement interior bulb socket
My Victory refrigerator was installed in 1986...The light socket assembly has disentegrated due to age? My refrigerator repair man says it's for an electrician to deal with,,,The electrician maintains that this socket assembly is a componet exclusive to Victory products and should be addressed by said repairman...Is it something that I can do myself? Where would I order the replacement socket from? Help! Thanks David
    Problem Solver:
  • 8 Answers
First off its the repair mans problem not an electrican, he probably knows its a hard job and does not want to do it, probably be alot of work to replace it, check with Victory an see it a replacement part is available an ask how hard to replace.
Posted on Nov 11, 2008
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Victory freezer VR1 evaporator motor will not run, does not have voltage to it. Fan delay switch checks ok....HELP!!!
Check to be sure the door switch is working. It turns the fan off when you open the door and turns the light on. Also the defrost time has a connection to the inside fan. Check to see that your defrost timer is turning on and off at the right times. If the evaporator coils don't get down to 20 degress the clicks-on fan controller won't switch on. If that is the case you may be low on refrigerant.
Oct 07, 2010 | Victory Commercial Freezer VSF-1
Lg premium ez digital i have a lg premium ez digital fridge freezer the interior light bulb has expired. how do i replace it please.
Unscrew it from the socket. counter clockwise. remove it entirely. screw in new bulb, clockwise
Sep 29, 2010 | Freezers
Hi how are you doinng , im carlos from tijuana mexico you can help me, i have a cuestion, we have a Hobart freezer model DAF2 but in the data plate make refrigerant type 502 my cuestion is what is the...
If the data plate says R-502, the cheapest and easiest one to use is R-408A. I have used it as a "Drop In" replacement for R-502 many times and it works just fine.
Just start by using about 80% of the amount suggested to be used for R-502. Then adjust charge to the desired temps and pressures.
Good Luck
Oct 20, 2009 | Victory Freezer Freezer, Reach-In, 2 Door,...
Aquired 3 door victory in existing bldg. Service
First check for bunrt wires that can be grounded, then you can disconnect the compressor and plug the freezer and if doesn't blow the breaker , the compressor is bad ,if still blows them ,put the compressor back and try the fan , then try the other fan(inside one) or also could be the light switch, or the defrost heaters.
Oct 06, 2009 | Victory Freezer Refrigeration ''Value''...
Fridge not cold at all.
check the adaptive deffrost control inside of the refrigerator compartment, more than likely thats bad.
Apr 05, 2009 | Freezers
Servis fridgefreezer light
IT COULD BE A BAD LIGHT SWITCH, SOCKET OR BULB.
IF THE CONTROL IS ELECTRONIC, SOME REFRIGERATORS WILL SHUT DOWN THE LIGHTS IF THE DOOR IS LEFT OPEN TOO LONG.
BE SURE THE BULB IS SCREWED IN ALL THE WAY. SOMETIMES, THEY WILL WORK LOOSE.
Apr 02, 2008 | Freezers
Freezers Logo
132 people viewed this question
Top Victory Freezers Experts
Dennis Boxerman
christian nielsen
David Emmel
David Emmel
Are you a Victory Freezer Expert? Answer questions, earn points and help others
