Question about Panasonic Panafax DX-800 Plain Paper Laser Fax
Panasonic DX-800 Fax Machine
I no longer have my owner's manual and I need to know how to fax to e-mail address.
  • Tracy Wallace Nov 11, 2008
    thx leroyal for your response to my query...i've gone through my help desk and they have set-up a ticket for it;-)
    Sergeant:
  • 284 Answers
Is the machine set up for your email
function 7-1-start and keep pressing start till you see what your looking for or use the arrows.
ipaddress
subnet mask
gateway if on a network
smtp and pop servers address
and to set one up you would press function-7-2-start-1"one touch" - press a speed dial key on the bottom and when it asks you to enter a phone number push the email button and program it in there., or just put the email in the machine and fax like you normaly would
Posted on Nov 24, 2008
    Genius:
  • 2,120 Answers
Do you an email server?
Posted on Nov 11, 2008
Dx-800 wont work with answering machine. Tried all the fax settings to use with a tam. Tam picks up line then dx-800 drops out everytime.
Set the answering machine to answer on 4 rings and the fax to answer on 6 rings.Do this with answering machine menu.
May 15, 2011 | Panasonic Panafax DX-800 Plain Paper Laser...
Panafax DX-800... shows memory full 100%. Scanner does not work. Pls advise how to cancel all memory as I do not need the incoming documents. Thanks.
Unplug the machine from the rear
Hold down the ENERGY SAVER key while plugging back in
Scroll down to ALL JOB CLEAR
Press SET
wait for the machine to INITIALIZE
Feb 08, 2010 | Panasonic Panafax DX-800 Plain Paper Laser...
DX-800 beeps with Incomplete Info Code = 720
Error Code 720: Cannot connect to the Pop Server. (Incorrect Pop Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the network Administrator
Regarding the beeping noises. The DX-800 has multiple settings for beeps, rings and the dialing monitor. If it is the latter, press MONITOR button once, then press the DOWN arrow, until silenced. Some ringer/beep settings are under Fax Parameters, some are in a special SERVICE MODE.
let us know if you can isolate which one and we can help turn it off. At least now you know what the 720 code means.
Good Luck!
Nov 10, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
DX-800 is locked up, it says "receiving a message"
Unplug fax machine
Hold down ENERGY SAVER key while plugging back in.
press SET
Wait for reboot
No joy?
Replace the main board.
Jul 23, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Code 721 keep coming up and the machine keeps beeping. How do we fix it?
Error 721: Cannot connect to the Pop Server. (Incorrect POP Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the Network Administrator
Were you setting up email by chance, you need to make sure the email server settings are set correctly for your POP email provider. Otherwise you will get this message. If you don't use email, go into settings (Fax Parameters) and disable email features.
Apr 27, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Won't answer and won't dial.
Use a plan phone to test first before attaching it to fax....
Mar 13, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Email
Verify that that the email address is valid by sending an email to them from a computer.
Sep 09, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Email address
Press function 62 and print out the one touch list and make sure the address is typed correctly.
Dx 800 fax machine
Only one sender, or all sender's?
Unplug the machine and replug. If it has an OUT button, make sure it's lit.
When all else fails...
Unplug machine
Hold down energy saver key
plug in
scroll down to SHIPMENT SET
press set
set
wait for reboot
Aug 20, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Faxes aren't being forwarded
Function 74 set
54 set
1 for invalid set
stop
Mar 27, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Panasonic Panafax DX-800 Plain Paper Laser Fax Logo
107 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
