Question about Panasonic KX-FHD332 Plain Paper Thermal transfer Fax
Phone line reversed
I used a phone line tester and it determined that the phone line was reversed.What does this mean and is it a problem because my telephones and computers all work fine.Thank you
  • nermonsun Jan 22, 2009
    I have a sperry tester and it reads line reversed, but my equipment doesn't work, what does this mean an how do i correct it
  • 146 Answers
The tip and ring (red and green) wires in the phone line are the ones that are used in this instance and there is technically no polarity (+ or -) because the current on this line is AC. Much like household current most device will work no matter which way the plug is inserted. There are polarized plugs which only work one way just to keep everything standard. Long story short: this should not be a problem under normal conditions.
Posted on Nov 11, 2008
My nokia 6288 is alway getting hot why? And what do i do
Any history of water damage? is the battery already deform or blowing? the phone might turn into some kind of shortage that is why it is getting hot, or the battery voltage is already open and needs replacement.
By the use of multi-tester, you can testify if the phone is shorted or some short circuit board,please follow this steps
* on your phone,locate the positive and negative terminal of the battery connector,usually both ends is the given polarity(facing at the back of your phone,positive is in the left terminal and negative would be the right terminal)
* on your multi-tester,switch the selector to Rx1 (resistance)
* using the red pin (positive) of the tester,hit the negative terminal of the phone.
* using the black pin (negative) of the tester, hit the postive terminal of the phone.
* if the tester meter don't respond,it means the phone is normal and that's the time you need to replace a new battery.
* but if the tester meter raise high or even a little,that means the phone is in short circuit problem,again,if the phone is water damage,dismantle the 4 screws at the back of your phone and release the back cover,carefully remove the flex connector attach,now lift up the pcb or motherboard,clean it pcb using any rust solution and toothbrush,dry it after,now assemble the phone and make a test again.
* if the phone still got meter rating on the tester,better bring the phone to a mobile service center for a complete diagnosis and troubleshooting.
Thank you for using Fixya...
Sep 22, 2011 | Nokia 6288 Cellular Phone
My Lexmark 7675 says phone i use but there is no phone in use on the line. I unplugged the phone cord and it said still phone line in use
This message appears when the printer is in the process of sending a fax - it has nothing to do with an actual phone being used - it can function when a phone is atached on the same line and is used (that is called On Hook Dialling). Normally it should detect that the line was disconnected so the sending should stop and a line error should be displayed. Since that doesn't happens it means that the unit is frozen.
The first thing is to try a simple power off/on : the printer should abandon the sending when powered off and resume normal function when on. If that fails it means that a fax got stuck and the next step is to empty the memory by reseting the printer to the factory defaults: turn off the printer (hold the power button pressed for 3 seconds); press and hold the green circle and the red x buttons then press the power button - keep them all pressed until the printer is fully on; release all the buttons and wait 15 seconds for the rest process to finish.
If you get the error even after that then either the firmware or the processor have been damaged. If it's the firmware the printer can be repaired simply by loading a new firmware - a complicated procedure that only a dealer can do. If it's the processor the entire motherboard would have to be replaced. That means the printer is dead, since it will be cheaper to just buy a new one. A visit to the repair shop of a dealer is mandatory, several tests will have to be done to determine which - it will be relatively expensive.
Aug 15, 2011 | Lexmark Office Equipment & Supplies
My battery just went dead and phone wont charge. I took the battery out overnight and it came on till the battery went dead again. I have removed and inserted battery several times but nothing happens.
It is better change the battery first,know if the phone runs in good condition as well as it charged after a low battery level, when the phone still got the same problem,your phone might be shorted were the value of resistance is double using a multi tester. To test if your phone is grounded,you need a multi tester and range the selector to Rx1 * tap the positive pin in the positive battery terminal of the board as well as the negative pin into the negative battery terminal too,the meter should raise up. * now tap the negative pin of the tester into the positive battery terminal and the positive pin into the negative battery terminal,if the rate is 0 it means the phone is good,but if raises high,it means the phone is grounded and had a power supply problem.in this case,bring the phone to a mobile service center for a complete diagnosis and troubleshooting.
Jul 27, 2011 | RIM BlackBerry Curve 8310 Smartphone
Philps match line flat screen tv red light flashing on the tv wont turn on
hello sir..your problem is usually happen when the circuit have shorted parts transistor or even diode...try to test by using multimeter tester range it diode testing for digital tester and for analog range it to ohms..first step is find the base of the transistor.then go for forward testing your tester should got reading after that reverse your test prove if the reverse testing got a reading it means your transistor shorted if not that is in good condition remember when you go for that testing procedure you should remove the parts to the circuit by using soldering iron and soldering pump..if my solution is helpful please don't forget to rate my answer thank you very much
Mar 06, 2011 | Televison & Video
The panasonic kx-t7633 has a flashing light but not dial tone
What color is the flashing light? Green is an intercom call and red is a call from an outside line. First try a new phone line cord and check if you have a bad cord. Do you have dial tone at other phones/jacks in the building? Unplug the extension line and plug in a known working phone. The phone needs repair if the your alternate phone works. If the second phone doesn't work at the jack, then the problem is in the wiring (at the jack or in the rest of the wire run) or in the Phone system. Depending on the jack, you can open it up and determine if there are any loose/broken wires. A cable tester that can do telephone lines (RJ-11) will help (some of these will handle power on the cable so check the specs for your phone system). If the jack uses a keystone, you will need to open it up and press the wires back down with the appropriate punch-down tool. You may want to pull the wires up and press them down at a different point (closer to the outlet box).
If none of the phones work then it is the phone system or the wiring coming into the building. I do not know if you can get to the service box and plug in a phone there. If there is no dial tone at the service box, get the phone company to fix it. If the problem is the phone system, you will have to consult a service person who knows more about the system.
I hope you find the problem to be simple, like a bad cable.
Aug 17, 2010 | Panasonic KX-T7633 Corded Phone
Noise on phone line - noise disappears when Gigaset SE587 router is switched off. Have changed ADSL filters to no avail.Any ideas? Rob Stickland - rmstickland@lineone.net
physically add a filter... goto radio shack or compusa and ask them if they have a phone line filter... if that doesn't clear it up then you have to talk to your phone company ( the one that maintains the line )
Dec 10, 2009 | Computers & Internet
Charge light stays on battery and alternater are good
If the red charging light is on, it generally means one of two things: either your alternator is not charging or your battery is too weak and is not charging properly. It also could be a wiring problem in the charging system. The method of testing the charging system is to use an inexpensive alternator tester that clips over the battery cable and indicates positive current. Some of the major auto parts stores have testers available for free loan and may help you with it if you desire to try to fix it yourself. The problem is that the alternator is expensive, so you will want to be sure what the exact problem is before spending money. Inexpensive current/charging testers are available to determine if your alternator's output is sufficient. This should be your first thing to do, which is to determine where the problem is and if its not the alternator, its probably a wiring problem and/or poor battery or corroded battery terminals. It's also possible that your system is charging but there is a current drain somewhere. An in-line current tester connected to the battery will determine if that is the case.
Oct 03, 2009 | 1991 Ford Festiva
New vtech phone model cs6229-3 headset keeps saying line in use
These phones look at the voltage on the line to determine if the line is in use.
Do you have any devices on the line that get power from the phone line? If so, they may be loading down the phone line causing this issue. If you have these types of devices on your line, try disconnecting those devices and see if the problem goes away.
Otherwise, your phone line may be defective. You may need to contact your phone company to get the problem resolved.
Sep 13, 2009 | Vtech Cordless 6041 Phone
Phone line reversed
Phones only use two wires Just reverse the two wires on that jack.
Feb 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Panasonic KX-FHD332 Plain Paper Thermal transfer Fax Logo
1,253 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
