Apple iPod classic 6th Generation Digital Media Player Logo
Tyler Gaston Posted on Apr 09, 2012
Ipod classic has software issues - Apple iPod classic 6th Generation Digital Media Player
Anonymous
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 28 Answers
  • Posted on Apr 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Night Owl:
Answers
28
Questions
0
Helped
3642
Points
60
Dear sir or madam,if you are having problems with your iPod classic i would recommend plugging it into your computer, opening iTunes and clicking on the restore button. If you continue to have problems with your iPod classic take your iPod to your local apple store with a genius bar appointment already set up and they will help you furtherI hope this helps and that you fix your iPod
How do i restore my ipod classic?
Take complete Back up of your files before restore your device at any time .
  • Re install the latest version of iTunes.
  • Open iTunes, and then connect your iPod to your computer.
  • after few minutes it will appear in the source list in iTunes.
  • Click the Restore button
  • Possible restore options are appear on screen.
  • A message will appear prompting you to enter an administrator's name and password. wait for some time and at last it
1helpful
My new Panasonic SC-HC57 is showing a 'checking connection' message when I put in my ipod Classic into the dock. I've upgraded my ipod to the newest software through iTunes, but still no
Not all ipod classic work with your SC-HC57 you need an older Panasonic SC-HC30 to work with that ipod :( or an iphone or ipod touch to work with your SC-HC57
Deck won't recognize Ipod classic. It does work with iphone 3G
make sure the ipod classic has up tp date software on it. ive had this problem before and the ipod had old software on it. should work just fine unless something is wrong with the ipod classic. good luck
My ipod classic only shows the apple logo and nothing else
I would hold the menu and center button at the same time until you get an error from itunes that the recovery software is downloading
then restore the ipod
if this dose not work it is probably a hard ware issue and you need to get the ipod repaired
3helpful
2answers
Apple iPod classic will play for 30-45' then will
1. Try doing a 'Restore' from within iTunes 2. If iTunes can't see the iPod it's possible that the hard drive is dead or dying. 3. If it's under warranty (12 months), take it to your nearest Authorised Apple Service Centre and they will get it exchanged in a couple of days
No warranty? Google "iPod repairs" in your country and you should be able to find someone who can fix it. The usually have a self diagnosis on line so will get an idea of the cost before you begin
1helpful
My ipod has a circle red x on it and wont respond
First try resetting the iPod. If this does not work then restore it.
To RESET IPOD: 1 Toggle the Hold switch on and off (slide it to HOLD and then back again). 2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
To RESTORE IPOD To update or restore iPod classic: 1 Make sure you have an Internet connection and have installed the latest version of iTunes from http://www.apple.com/itunes/download/?ipod 2 Connect iPod classic to your computer. 3 In iTunes, select iPod classic in the source list and click the Summary tab. The Version section tells you whether iPod classic is up to date or needs a newer version of the software.
In Restore all data is erased from iPod classic, including songs, videos, files, contacts, photos, calendar information, and any other data. All iPod classic settings are restored to their original state.
2answers
IPod Classic won't play video with AV Component Cable
I have the exact same problem, having previously tried the component cables. I called tech support who stated that my ipod classic must have some sort of hardware malfunction when otherwise fully functional. I can get sound through the RCA cables, but no video. What gives?
Ipod classic not working
Hello deepthi,
You probably have a bad firmware. If you have an old firmware back up you are advised to restoreit.Otherwise just update your Ipod's software through itunes and it should be fine..
Ipod classic
Make sure you have you user's manual. If you don't have it, go to Apple website.
Make sure the songs you are trying to add are in the format suggested in the user's manual - warning: WMA files are trouble for reasons I don't feel like explaining anymore.
If they are, then make sure that you still have enough memory left in this player.
If you do have enough memory, follow Apple's 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
