Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Problem for Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Wall heater does not work!
By bamwood on Nov 11, 2008
I have a tri-plex in CA built in 1949. The 1 bedroom units have small heaters built into the wall. They are not very efficient, if they work at all.
I can not get one of the units to even light? I've replaced the gas valve and a thermocouple. I even blew out the gas nozzles and the burner area. Still I can't get the burners to light. The pilot light works but that's all. The place I bought the valve from says that's all I should need. I'm not sure of the model numbers If they're there, they have 30 coats of paint over them.
Any suggestions?
Solution #1
posted on Nov 26, 2008
Not Rated)
jjplumber
Rank: Master
Rating: 79%, 8 votes
it sounds like the gas valve is not getting power. There is probably a saftey device that has tripped, preventing the voltage (24v) from energizing the gas valve. check for 24v throughout the circuit. It should be a simple series circuit.
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Questions and Unsolved Problems for Honeywell Power Humidifier:
Do you recommend Honeywell Power Humidifier: Furnace Humidifier/ Humidifier?
Answer
Answer
i have a he260 humidifier and the water does not stop running
Answer
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem... (More)
Answer
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on... (More)
Answer
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and... (More)
Answer
i just replaced solenoid and humidistat onn my furnace himidifier but when i turn on humidistat to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Humidifier Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
