Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
My HE3 washer, about 4 yrs old is locked , showed error code 6
The washer was making a lot of banging in the final spin, with 2 min to go in the cycle, the alarm went off, it showed error code 6 and shut off. It wont turn on & I cant get the wet laundry out
  • 370 Answers
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the control is unable to properly detect motor speed. Due to this the machine shut itself down.
Posted on Nov 21, 2008
My washer goes into spin cycle byitself and when washing,if u r in spin cycle it sets for 14 mins thats good 4 mins into spin all knob lights start flashing and the screen says uL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
Jan 23, 2011 | Washing Machines
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
My washer will not spin out, it is not flashing
intersting when mine did this it was the pump... maqy i ask how you checked your pump? and can they be cleaned i just had to replace mine and its only 2 yrs old, i dont want to have to replace every 2 yrs
Dec 30, 2009 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Calypso Mod: GVW9959KQ2, stops and shows "ob" as code for fast final spin. Also making high pitched whine during wash cycle. Appl svce place has suggested bearing or xmission. Any possible...
Sorry to say but they are right. The Calypso washer was a horible design given to whirlpool from maytag. I would suggest you go buy new machine. Buy someting that looks simple and easy to use. The more complicated the unit the more problems you will have down the road.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore HE3 washer started knocking and shaking during spin.
indicates that the tub support rods have failed at the air dampners
the fix is new rods from the service agent spares and a re levelling if the tub ,not the machine
Nov 20, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Feb 22, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
125 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
