Question about Philips 26MF605T/17 26 in. LCD Television
TV leaking clear liquid
I had prchased a 42 inch Phillips lcd flat screen TV from Aarons sales and lease had it for a while and on Halloween I discvered a clear liquied all around it on the tv stand the tv has never been hit or dropped no drinks have been sit beside it any idea of what theis could be?
  • 4234 Answers
SOURCE: phillips 42 inch tv
The stand base part number is 310430814621 and is available for $71.58 from
Posted on Jul 30, 2008
  • 6 Answers
SOURCE: 42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check
for more detail.
Posted on Mar 03, 2009
  • 61 Answers
SOURCE: TV freezes at "Philips" screen
a professional. -These electronics go threw a self diagnostic when they start up, normally they turn off when they find a problem.
Posted on Jun 01, 2009
SOURCE: Phillips 20 inch flat tv
sound keeps going up to full and remote wont bring it back down to level i want
Posted on Dec 25, 2009
SOURCE: screen is black but we have sound
The problem is a faulty inverter kit (2 boards).
I live in the Netherlands and had it twice, tv is 2 and a half years old! In the Netherlands Philips replaces the inverterkit without any
costs for the consumer (even after warranty time) cause they have
admitted that it is a production fault.Philips made a new inverterkit
which should solve the problem indefenit.Be sure the kit is Version
1.3! I had 1.2 after the first problem, and that went wrong after 7 months again. Today got revision1.3 installed which is Philips final solution.
Posted on Jul 21, 2010
Testimonial: "Thanks very much for your help. I will contact Phillips Ireland and see what they can do.Thanks again"
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
Dec 20, 2015 | Televison & Video
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
Aquos LC-42D62U 42 in. HDTV LCD Television: 46 inch lcd screen hit with an object and cracked,...
Sorry,no! Because the LCD screen is about 90% of the LCD tv.No where else u will find a LCD screen for sale.Except the tvs corporation themself,LCD screen it limited produce,so the will charge u the LCD screen replacement same as a new tv or even more after the labors and LCD screen replacement.Ur tv now it only can be salvage as for electronics boards for parts that it.Not worth as a whole tv any more.
May 16, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My 42 inch lcd phillips tv turns on and of by its self and freeze
If it is still under warranty address this. The problem is the signal board. The one with rca jacks and RF connectors.
Aug 19, 2009 | Philips Televison & Video
Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
My phillips 42" HD Flat screen won't turn on
I switched the power cord with the one to my desktop monitor and it worked ..i noticed the end going into the TV had some discolor to it ..I put the one from the TV into my desktop monitor ..and that worked too..must of been a shortage of power from the cord to the TV?
Jun 11, 2009 | Insignia 42" LCD Flat-Panel HDTV
No I need a screen for a LG LCD 42 inch TV . .My
a new screen is like a new tv $1000 - 1500 for a panel
May 12, 2009 | LG 42LG50 42 in. LCD HDTV
you should take down the tv and and clean it. try and mix vinager and water together then wipe the tv down.
Oct 16, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 42 inch LCD HDTV w/HDMI
Dec 11, 2007 | Philips 42PFL5332D 42 in. LCD Television
Open Questions:
Philips 26MF605T/17 26 in. LCD Television Logo
728 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
