Projector Television Panasonic TX-47PT1 EURO5-VP Chassis The fault is the BLUE Digital Convergence Grid bows up from the bottom of the screen quite a lot, and also bows down slightly from the top. The RED and GREEN Digital Convergence Grid is normal. Any solutions would be greatly appreciated Regards Alan
  • tecpos Nov 11, 2008
    I will now endevour to purchase & replace the convergence IC chips.
    Many thanks
    Alan
    Genius:
  • 1,550 Answers
TV in Service 2 Mode.
Select Static Convergence (Access by [BLUE] button)
Static Convergence
Using the Channel UP/DOWN and Volume LEFT/RIGHT buttons, align the Green Horizontal and Vertical test marks with the Screen Frame mechanical reference marks.
Press N button to cycle through options and exit Static Convergence Mode.
If Test Marks Is Aligned,
Select Point Convergence
Press RED/GREEN button on remote until "Point Convergence" is displayed.
Press BLUE button on remote to enter Point Convergence Mode.
Copying Procedures
Point Convergence Mode must be active prior to copying data.
Press the Copy Key ("C" on the numeric keypad).
Using the Cursor UP/DOWN buttons, select the plane that is to be copied. Press Enter key (N button).
Using the Cursor UP/DOWN buttons, select the destination plane. Press Enter key (N button).
Else - Align Static Convergence
Note. When performing a complete convergence alignment, set all data of Static Convergence to 0 (zero). This will creat a zero reference when convergence is completed.
Install Alignment Template
Convergence Alignment Template (Parts NO.TZSC07014)
The Convergence Alignment Template is a grid approximately the size of the viewing screen used to ensure the proper size and shape of the alignment rasters. It is 10 blocks across by 8 blocks high. The grid dimensions will vary according to the size of the screen. Apply a Convergence Alignment Template to the viewing screen of the TV. Make sure the center lines are properly aligned. If a template is not available, one can be created by following the instructions below. Great a Convergence Alignment Template by drawing the pattern to the right in the actual dimensions on transparent film or tracing paper. Start with the Horizontal and Vertical Center Axis and work outwards until the pattern is complete. Pay close attention to the actual dimensions of the pattern
Posted on Nov 11, 2008
  • SAM ANDERSON Nov 11, 2008
    I got this information from
    http://www.digitalspy.co.uk/forums/showt...
  • 13,433 Answers
I suspect it is a issue with the convergence IC chips
replacing the blue convergence IC would most likely solve the problem
see this page http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Suggest you replace them all.
If this kind of repair is outside your comfort zone I would suggest to take it to a repair man.
    Sergeant:
    Novelist:
  • 196 Answers
On the main board there is a convergence STK ICS u just have to replace that ics to make it clear.
I have a panosonic TX-47PT1. No problem since new. 3 days ago the convergance went. The colours (mainly red ) have slightly seperated and become a horizontal wave. I have read the forums and it seems there...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 02, 2011 | Panasonic PT-51HX43 51" Rear Projection...
There is a wave/bow in the bottom and top of the picture on the screen of my Toshiba 70HX50. When I am in the grid screen in the service mode it looks like the center is 'bowed' out. How do I adjust this...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Toshiba 43H70 43" Rear Projection...
Projector out of alignment
Ur convergence is dead,buy convergence kit use what inside that kit,U know how to solder right?Tries website Tv Repair World.com.
Sep 28, 2009 | RCA P61960 61" Rear Projection Television
Bowed picture on Panasonic PT-53WX52F
Problem #1 - CONVERGENCE PROBLEM
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 04, 2009 | RCA HD52W59 HDTV Projection Television
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
  • Screen looks 3D
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
TV turns off by itself
  • Screen looks 3D
Feb 03, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red bow on top and bottom of 61dx01b
  • Screen looks 3D
May 21, 2008 | Samsung PCL5415RB 54" Rear Projection...
Panasonic- 47wx42f
the convergence ic's are at fault need replacing,call a service shop and ask for estimate to repair .should be under $ 300.
Dec 09, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Pioneer elite Projection TV PRO-98
Need to replace the convergence board. Cost through Pioneer is $350.
Nov 25, 2007 | Televison & Video
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
