Question about Canon EOS-AE-1 35mm SLR Camera
Stuck shutter-button I love this camera and need help. The Shutter-button is stuck all the way down. Anyone have any advise. Thanks so much!!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
Either just drip small amount of methilated spirits or benzine at the rim of the release button and lift with tweezer ( tweezer into the center of the button ) repeat several times . If this fails remove top cover and clean the shutter relase from inside.
Posted on Aug 25, 2007
Lcd screen does not show scene and photos are all black. can anyone help?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 22, 2011 | Kodak EasyShare DX7630 Digital Camera
I have a Powershot SD960 IS digital camera. I turned it on and there is no image showing....I touch the menu button and nothing happens. I took my memory card out and put it into my PC i see pictures on...
Sep 29, 2011 | Cameras
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
My canon powershot a430 has always given me beautiful pics! I love it. but now I can only take pics inside. when I take pictures outdoors they come out white. what can I do to fix this problem?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, recommend trying the pencil tapping method described in this article for a stuck "open" shutter.
Jul 30, 2010 | Canon PowerShot A430 Digital Camera
I can open my camera but the view screen is blank! Help!
Press the DISP or DISPLAY button. If that didn't fix it...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 17, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Lcd screen is black
First of all, make sure that you didn't just accidentally turn the screen off. Press the DISP or DISPLAY button on the back of your camera with the camera turned on. This button manually turns the screen on and off to save batteries.
OK, you already knew about that button. Don't get offended, a lot of people don't. Take a picture with the screen black, and download it to your computer. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Mar 28, 2010 | Canon PowerShot A630 Digital Camera
Camera shows no image through the viewfinder or on the lcd screen.pressing shutter button will actuate the camera, but only image is of a black box.using the display button to turn off the lcd does not...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 18, 2009 | Canon PowerShot S3 IS Digital Camera
Displays icons but won't register pictures
First make sure that you accidentally didn't turn off the screen by repeatedly pressing the DISP button to cycle it on and off. If that didn't fix it, and if your camera is less than 1 year old, call 1-800-OK-CANON to arrange free warranty repair.
If your camera is more than a year old, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Canon PowerShot SD1100 IS Digital Camera
My canonpowershot SD750 digital camera is coming as a black scree
Jul 02, 2009 | Canon PowerShot A550 Digital Camera
Black pictures
Jun 27, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon EOS-AE-1 35mm SLR Camera Logo
275 people viewed this question
Top Canon Photography Experts
old marine
old marine
TC CAMERA REPAIR.Com...
Norman Worley
Are you a Canon Photography Expert? Answer questions, earn points and help others
