Question about Rosen CV7080D Portable DVD Player
Two dvd's stuck in player thanks to a busy toddler
Any way to get two stuck DVD's out of my system? My two year old was being helpful and stuck two disks in at the same time. System won't eject.
Thanks
I had the same problem... my DVD took one in even though it already had one in there... Tweezers did not work until we used a pie server covered in masking tape with the DVD attempting to eject and then grabbed one DVD out. The DVD player works too!
Posted on Jun 28, 2010
I had the same problem and read on another site to use needle nose tweezers. worked like a charm, only took about 5 mins to get them both out...someone also suggests trying a putty knife with tape wrapped around it.
my dvd player still works great and both dvds work too.
Posted on Dec 24, 2008
Previous solution surprisedly worked! After trying several techniques, found the masking tape wrapped around a knife-sticky side on blade-worked splendidly..putty knife would be better-almost cut myself getting masking tape off knife! Oh yes, made sure there was no weight pushing down on top of player!
Both DVDs out - everything good
Thanks to you folks with your generous solutions!
Posted on Aug 15, 2011
I had the same problem, two DVD discs stuck in a DVD player .first make sure that the eject button is on , then try to pull out one disc with a tweeser, once the first disc comes out the next one will come out automatically.
Posted on Apr 21, 2009
My daughter inserted a 2nd DVD while there was still one in the player. Neither dvd would eject. Tweezers and spatulas did not work for me. I opened the screen, tuned off ignition and removed the rubber plugs, then unscrewed four long screws holding the unit in place. Then carefully removed power supply and closed dvd screen. Continued to unscrew about 10 - 12 little screws holding on top plate and removed plate. Unscrewed four little screws holding dvd player, just lifted the plate enough to pull out the dvds. Put everything back together carefully - needed another pair of hands to help while putting power supply back together, turned ignition on, then opened screen and replaced four long screws and rubber plugs. Everything worked again, no damage to unit or dvd's. Saved myself $80 for call out and 10 mins work!
Posted on Jun 13, 2011
    New Friend:
Thanks do much for the tape and pie server tip! It worked like a charm. I used a flat small metal ruler and some painter's tape.
I cannot thank you enough.
Posted on Nov 11, 2017
    New Friend:
We used a thin plastic ruler wrapped in tape at the end. Easily brought out both DVDs and player still works!
Posted on Oct 27, 2014
3 Suggested Answers
ekmoetweet
  • 124 Answers
SOURCE: The DVD gets stuck inside
Open up the dvd player (first unplug) by loosening screws on side and back take out disk and clean round spindle the disk is sticking too.
Posted on May 11, 2011
kerguney
  • 577 Answers
SOURCE: A dvd is stuck in
Hi.I do not know if you can do it but no other way..Lets try it..
Please got a screwdriver and open the DVD case from the sides and back. It is simple, just some black screws. Then look in the unit and see and gently remove the disks by plastic holder open and sliding the disks out.
Then put the cover back on and put the screws back in. Should Work fine now.
I hope this helps you. Good luck.
Please let me know if you need more help.
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Posted on Aug 26, 2011
Disk won't eject
Normally all readers have a mechanical system that can be accessed from the front or the back of the reader to open using a small tool. Normally it's a little hole (like on smartphones) where you can insert a metal piece and push on it to eject the drawer.
May 30, 2017 | LG RHT599H 500GB HDD DVD Recorder with...
Tip
DVD player in my home theater system won't eject the disk inside.
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be disassembled to remove the disk.
on May 04, 2009 | Philips HTS3450 System
I have a 2007 Honda Odyssey with the built-in DVD player. Now there's a DVD stuck in it, it won't play and it won't eject. Help!
if you look closely enough there is a small hole on almost any sound system if you do have one put a paper clip in there and wiggle it around a little bit youll hear a click and the system should eject the cd if not then the cd has jammed in there and shattered which means you will have to pay a profecional to take out the dvd and get the disc out. hope this helps and if not well i apologise
May 13, 2011 | Car Audio & Video
Will not eject disk.
Almost always, your described problem could be caused by:
  • stuck disc;
  • fault in the load/eject mechanism.
It it were a stuck disc, the correct fix would be to open the unit and manually extract the erring disc. However, there may be possible workarounds:
  • unplug the unit for an hour or so;
  • press and hold the eject button while plugging in; or
  • invert the unit (bottom side up);
  • plug back the Apex and quickly unplug soon as you hear the mechanical noise start;
  • revert to normal position and try ejecting; or
  • while still in the inverted position, press and hold the eject button while plugging in but must unplug quickly even before the tray starts to move out.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 15, 2010 | Apex Digital AD-1225 DVD Player
DVD drawer will not open - stuck dvd inside
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
May 15, 2010 | Bose Lifestyle 28 System
Hts 3450 home theatre system- dvd in player- but won't come out
Unplug power cord.
Plug back power.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Dec 10, 2008 | Philips HTS3450 System
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Disk wont eject
tough luck buddy, this system is sh!t. i'm on my second and have now got a similar problem with the second system. I eventually took a pen knife to the first unit to get the dvd out and then managed to get a rented dvd stuck in the machine a week later.
Aug 17, 2008 | Philips HTS-6500/37 System
DVD tray will not open
Unplug power cord.
Plug back power.
Feb 25, 2008 | Dual Presidian DVD Recorder
Rosen CV7080D Portable DVD Player Logo
4,892 people viewed this question
Top Rosen Televison & Video Experts
Jim London
Jim London
Are you a Rosen Televison and Video Expert? Answer questions, earn points and help others
