Question about Ovens
Kitchenaid superba electric oven kebc107kss05
It's just out of warranty about 15 months old probally been used 20 times everything on display seems to be working OK but it want heat up at all and if you smell inside it smells like burnt up wire or something like a elec. fan motor that burnt up....mwi
  • 2 more comments
  • Anonymous Jan 22, 2009
    Same issue.  Started after entering cleaning mode.
  • artonthemind Feb 17, 2009
    Same problem, will not heat up and has weird wire smell on inside
  • jenniferfree Mar 24, 2009
    Exact same problem: cleaned it once using the self-cleaning mode.  Now it has a funny smell inside and won't heat up at all.
  • Dylan18560 May 04, 2009
    Wow, we just googled this and found that we have the same problem. We just did a self clean last night, and now we can't get it to work. What the hell? We're calling KitchenAid
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Posted on Dec 01, 2009
I have had the same problem twice with my wall oven Kitchenaid model KEBC107KSS05. Oven stops Heating after the self cleaning feature is used. The only solution is to keep replacing the thermostat, until you replace the oven with a product other than Kitchenaid.
Posted on Jan 11, 2010
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Jul 15, 2009 | Ovens
Will not heat.?
Double check the ground and bond wiring. Watch yourself because if the ground wires ARE faulty then you'll be the ground! This could be a very dangerous situation so if in doubt call in a real electrician.
Jul 08, 2009 | Jenn-Air W30400P Stainless Steel Electric...
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
GE: JTP56 F2 Door Locked displayed
I have the the same problem as discribed above. Does you oven fan go on for a long time after you use your oven during regular baking. Mine seems to stay on for 45 minutes after I bake anything. Can this be all tied together with the f2 problem? I am wondering if it is not just a fan circulation problem?
Dec 15, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
957 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
