Question about Brother P-Touch 1180 Label Printer
LOADING TAPE CASSETTE
I HAVE A OLDER BROTHER P-TOUCH AND IVE LOST MY INSTRUCTIONS. I CANT FIGURE OUT HOW TO LOAD IT. THIS IS MY 2ND TIME TO PUT NEW TAPE IN IT I TURN IT LOAD IT THEN TURN IT ON AND PRESS PRINT. SOME BLACK LABLES COME OUT THEN NOTHING ,AND IT MAKES A WEIRD NOISE AM I NOT LOADING IT RIGHT? THIS TAPE IS EXPENSIVE AND THE BOX IT COMES DOESNT SAY ANYTHING I WOULD REALLY APPRECIATE YOUR HELP THANKS SO MUCH
  • 1 more comment
  • dpoindexter Nov 17, 2008
    I HAVE A BROTHER P-TOUCH I DO NOT HAVE THE INSTUCTIONS AND I CANT GET IT TO LOAD I PUT NEW TAPE IN IT AND TRY TO PRINT BLACK AND WHITE TAPE CAME OUT KNOW NOTHING COMES OUT AND IT MAKES A WEIRD NOISE I THINK IM LOADING IT WRONG ANY ADVICE? PLEASE AND THANK YOU
  • irkabiala Jan 11, 2009
    I can't loading the cassette , The black toner ( black tape with the print) just go with out the white tape.Look like the white tape some how go inside the cassette , not out side .I can get the white tape form plastic cassette .Look like the tape is deep stay inside the cassette .
    I just get brand new .What i need to do ?I will need bay the new ?
  • debbie_just_ Jan 20, 2009
    i cant load my tape i have lost my instructions....it makes a noise put doesn't take the tape
  • 120 Answers
Http://www.brother-usa.com/Manuals/default.aspx?ProductID=PT1830&ProductGroupID=8
Click the link above, select the model you have and download the manual (1180 is in the list).
Hope this helps.
Posted on Dec 05, 2008
I have a Brother label maker, model number pt65. How do I install the tape. I cant get it to feed through. Thank You
1) Remove the back cover by pressing in on the rough
area at the top end of the machine and pulling off the
back cover.
2) If a tape cassette is already installed, pull it straight out
and remove the paper tab from the new tape cassette.
Make sure that the end of the tape in the new cassette
feeds under the tape guides.
3) Insert the tape cassette, making sure that it clicks into place.
Check that the cassette fits properly around the two
metal guides in the cassette compartment.
4) Attach the back cover by inserting the two hooks on the
bottom end of the back cover into the slots on the bottom
end of the machine, then pushing down firmly on
the cover until it snaps into place.
5) Feed the tape by holding down and pressing ,
then cut the tape by pressing in on the tape cutter button.
The amount of tape remaining is visible through the
window in the back of the P-Touch.
When the usable tape is finished, green ribbon appears
Hope this helps
Bruce
Jun 14, 2011 | Office Equipment & Supplies
How do i change the tape on it?
This machine uses the Brother TZ tape, which is available in a variety of colors and three widths (1/4" (6mm), 3/8" (9mm) and 1/2" (12mm)). A TZ tape is supplied with this machine.
1 Press in on the rough area at the top end of the machine and fold open the back cover. Should be the exact process as loading batteries.
2 If a tape cassette is already installed, remove it by pulling it
straight up.
3 If the ink ribbon in the other tape cassette is loose, use your finger to wind the toothed wheel in the direction of the arrow on the cassette until there is no slack in the ribbon. Also, make sure that the end of the tape feeds under the tape guides. Note: If you are using a new tape cassette provided with a stopper, be sure to remove the stopper.
4 Insert the tape cassette firmly into the compartment, making sure that the entire back of the cassette contacts the bottom of the compartment. Note: When inserting a tape cassette, make sure that the inner ribbon does not catch on the corner of the metal guide.
5 Securely close the back cover, making sure that it snaps into place.
6 Feed the tape by holding down CODE and pressing PRINT once, and then push in the tape cutter lever to cut the tape.
You can also get a copy of the user's guide here.
Thank you for using FixYa! Don't forget to rate our service.
Feb 10, 2010 | Brother P-Touch 1180 Label Printer
We lost an instruction for inctalation
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_1700_ENES_1389.PDF
This is URL for your manual. Save the .pdf on your computer and you will have info at your fingertips anytime you need it.
Jul 17, 2009 | Office Equipment & Supplies
Wont load tape
HI, this is a mechanism fault beep you are hearing. the mechanism and load motor is damaged. you will need to send this unit to the Handy cam repair depot for this repair. you will need a new load motor and loading dock mechanism as well.
Jun 03, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony DSR-1500P does not load tape
There should be smoe indication on the front of a problem. If not, then the load sequence is not completing and the unit should be sent in for service. These are pro decks that should only be serviced by trained personnel. There are a number of reasons why a taoe would not load. Without seeing the unit, it is extremely dificult to determine the cause. Are there any other details you can provide that might help me to determine possible causes? Can you observe the loading to see how far it gets?
Thanks,
Dan
Feb 05, 2009 | Sony DSR-1500 Mini DV VCR
LOADING TAPE INTO A BROTHERS P-TOUCH
I'm on my second machine since December. Neither P-Touch would feed the white tape, the other layers bunch up inside the machine. Called Brother, and they were no help (indeed not much interested in my problem), except to suggest I clean the rollers with alcohol/q-tip. This action did result in the tape feeding, but not properly as I now get an unusable label strip with all three layers, and printing on the clear layer backed by black layer. POS if you ask me; it is going back to the store.
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
Loading a cassette
having the same problem...when I put a new tape in it just ejects it right away!
Apr 17, 2008 | Canon ZR200 Mini DV Digital Camcorder
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Sony slv 700 hf
The VCR is detecting something it doesn't like. Could be a foreign object inside, or the gearing out of time or ... Take the cover off and watch it as it loads and you'll probably figure out why.
Dec 29, 2007 | Televison & Video
Brother P-Touch 1180 Label Printer Logo
630 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
