Question about Smeg CSU2001 Built-in Dishwasher
Help i have a smeg dishwasher, which until recently has been perfect,it seems to be stuck on its cycle and is making all the noises of working, but nothing is happening, then the panel says E 1. any ideas what is wrong and what can i do? thanks to anyone that can help
We have a Smeg SA8605W which has had a similar problem 3 times in its short 3 month life. The problem with ours is that the control panel on the front pushes against a very brittle plastic frame to activate the micro switches. Because of the brittle nature the 'fingers' of plastic break off and either get stuck holding the machine in a set cycle or break off fully so nothing functions. Gaffa tape or Elastoplast is a simple solution.
Posted on Jan 31, 2007
Amana dishwasher makes noise
something is probably down in the drain dish washer has a disposal like system at the drain
Sep 03, 2013 | Dishwashers
Smeg ST663 gets stuck onwash cycle
I have the same problem. If anyone has an answer I would be most greatfull.
Feb 11, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg dishwasher E1 error code, not filling up
Hi!
here are manuals to the number of SMEG dishwashers.
Hope you could find there your device and the "troubleshooting" part of it would help you!
https://manualsbrain.com/en/brands/smeg/dishwashers
Dec 07, 2017 | Smeg Dishwashers
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Will not finish the cyle and is not draining the water
more than likely your drain hose is plugged or something in the pump is plugging the drain hose using a wet vac the water out of the drain hose and see if you get water out of it if not take hose off from bottom and try reverse suction to ensure hose is clear most dishwasher will not complete cyc if float is in the up position and will not advance.
Aug 21, 2009 | Smeg 24 in. DWF614SS Stainless Steel...
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
Smeg CSU2001 Built-in Dishwasher Logo
527 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
