Question about Craftsman 4 Cycle Blower/Vac
Leaf blower wont dstart
I have tried for an hour, it wont start. It wa runnign fine last night, has fresh gas, but stinks of gas now
  • 163 Answers
Try replacing the spark plug.
Posted on Nov 29, 2008
Toro snowblowe car 2450 started first time but after about an hour refuses to start
Loosen the gas cap and try again. Many times the Fuzz that grows in the Gas areas due to Ethanol gas can also clog the Gas Tank Vent
Nov 12, 2014 | Garden
Sears snow blower runs rough like the choke is on
put in injector cleaner in gas
Dec 14, 2013 | Garden
I can't start my mower I pull and pull and pull and nothing
if the gas is left from last year drain it and try fresh fuel gas is only good for 30 days in small engines
Mar 26, 2012 | Garden
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
Have less than an hour on it since new and can't keep it running. Starts hard. Have tried every trick that I have read about on the online chats and am convinced that this machine is a P.O.S. Anything...
You may have tried this but fresh gas. If it only had an hour on it but it sat around for 6 months or a year, the gas may have gunked up. But you probably already knew that. If it is gunked up try putting a bit of straight gumout or the like (not the spray but the carb. cleaner you mix with gas. and let it sit a few hours or over night the try and start it with a full tank of fresh gas mixed with the proper amount of oil. NOTE: there does exist some possibility that this may ruin the carb so you may want to start with just a small amount of gumout mixed in W/ gas. but since it sounds like you are about ready to through this out . . .
Jun 29, 2011 | Poulan 25CC Gas BlowerVac
Mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Nov 02, 2009 | McCulloch 26cc Gas Blower Mcb3208
Wont start no life only has about10 hours on it. its getting gas. last time used was fine
when WAS the last time??? Spring? You probably have a gummed up carb if that is the case and you didnt use fuel stabilizer.
Does the gas smell old when you pull the cord?
You DO have spakt, right?
I suspect the fuel is **** - pour it out and put in fresh. You may get it to go. You might have success if you pour fresh fuel into the spark plug hole ... do this with extreme caution, BTW.
Oct 09, 2009 | Garden
My 2year old toro 6.0 lawn mower wont work i just took it out from the shed, it was in there during the winter and now wont work. it worked perfect before why is this not working someone told me its debris...
did you burn all the gas out at the end of year last year if not bad gas will leave deposits in the is a simple sugestion drain any gas out of it thats in it .put fresh gas in it and 2 table spoons of marvel mystery oil in gas tank you can get it at any auto parts store crank it untill you are sure fresh gas oil mixture is in intake wait an hour and let the fresh gas\oil mix do the work.pull plug dip it in fresh gas put plug back in and try to start it this often works if it dont you could have leaves .dirt .rust .or debris on surface of flywheel ,or a bad sheer pin on flywheel the sheer pin is whar times the engine on most small engines good luck i hope these sugestions help
Apr 29, 2009 | Toro Lawn Mower With Toro Power Tools
Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
Sep 29, 2008 | Homelite 'Yard Broom' Leaf Blower
Craftsman 4 Cycle Blower/Vac Logo
274 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
