Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Certain cycles do not operate
All the wash cycles on my dishwasher work except "Normal" wash and "both racks" (under light wash). These are the washes I use most often. However, when I press the button, it does not light up. I've already checked the electric outlet, etc., but still nothing seems to work.
  • 4 more comments
  • Keith in RVC Nov 03, 2007
    I am having the same problem. The "Both Racks" under "Light Wash" do not work and the "Normal Wash", "Hi-Temp Wash" and "Sanitize" do not work.
    I think a control module or something along those lines is failing. I assume the price of the electronics would put me in the market for a new dishwasher.
  • Anonymous Mar 17, 2008
    Will not start when you hit the start button
  • bradgslater Sep 03, 2008
    I have the same problem with the "normal" wash and "both racks" wash not working.
  • foxspit Feb 06, 2009
    identical problem, except we can use pots and pans and light wash, but not normal. you press the buttons and nothing responds. you'd think there'd be something on the frigidaire website on this one. i may try the "leave it unplugged for 15 minutes', then crack open the control panel and jigger around with stuff. what could go wrong?
  • avolcoff May 11, 2009
    same issue here
    do you have any workarounds?
  • hopey325 May 11, 2010
    So replacing the timer will make all control buttons work? I also have the same problem
So it is just a timer that is preventing the other cycles from working?
Thanks,
Keith
Posted on Jan 18, 2008
  • Keith in RVC Jan 18, 2008
    Is this part expensive?
    Genius:
  • 1,003 Answers
YOU JUST NEED TO REPLACE YOUR TIMER NOT AS EXPENSIVE AS A NEW DISHWASHER
How do I reset my Kitchenaid dishwasher that is blinking the clean light 4x
This post is saving me from buying a new dishwasher!! Thank you so much!! It hasn't worked in months
Apr 24, 2014 | KitchenAid Superba Architect II KUDE60FX...
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
My dishwasher will not drain after cycling. I have check the drain hose connected to the disposal. All is in good order the hose is not cinked and the air hole is unblocked. I have also checked the screen...
The problem is a solenoid under the unit. It is a small black cylinder that operates a valve to change from the wash cycle to the drain cycle. You can probably order a new one from Kenmore for pretty cheap.
Aug 18, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Normal wash cycle will not work. After I used the rinse cycle on day, I went back to the normal cycle and the lights wouldn't light up. Every other cycle will still run except this one.
Could be tricky to find this one.
You need to deduce what is used in the main cycle that is not used in the others,
Whatever is used is likely to need testing or replacing.
If there is nothing else wrong (heater, pumps, thermostats) then the only thing to try is a new control board.
May 02, 2010 | Frigidaire Professional Series 24 in....
AEG 250 operating manual
hi friend,
step 1
Remove any large food deposits from the dishes to prevent damaging the dishwasher.
  • Step 2 Load the upper rack of the dishwasher with smaller items, such as glasses, cups and cookware lids. The items must be inserted face down, with the soiled side of each item facing toward the bottom of the dishwasher. Some dishwasher models feature clips, which can be used to secure lightweight items to the tines of the upper rack. The clips work like clothesline pins, and can be moved from one tine to another.
  • Step 3 Load the lower rack of the dishwasher with heavier items, such as plates, bowls and pans. Insert the items between the tines of the rack with the soiled side of each item facing toward the center of the dishwasher.
  • Step 4 Load the silverware basket. The silverware should be inserted into the basket with some items facing up and some facing down to ensure the items do not fit together, which would prevent the dishwasher from being able to clean all surfaces. Knives should be inserted blade down, so they can be inserted and removed from the dishwasher with the handle to avoid injury.
  • Step 5 Add detergent to the dishwasher, and then close the dishwasher's door. Note that the dishwasher has two detergent sections. One dispenser, called the main wash section, has a lid. Open the main wash section's lid by pressing down on the cover latch located next to the section. Fill the main wash section with 3 tbsp. of automatic dishwasher powdered detergent, then close the lid until it snaps into place. The other detergent section is the prewash section. It does not have a lid, because the detergent within the section empties into the dishwasher when the door is closed. Fill the prewash section with 2 tbsp. of automatic dishwasher powdered detergent. Close the dishwasher's door until it clicks into place.
  • Step 6 Prime the dishwasher by turning the kitchen sink's faucet on until it produces hot water. This will ensure the dishwasher has an immediate supply of hot water.
  • Step 7 Start the dishwasher by choosing and pressing the appropriate wash-cycle button, located on the front of the dishwasher's door. Cycle selections include "POTS --N- PANS," "HEAVY" for heavily soiled items, "NORMAL" for standard washing, "CRYSTAL/CHINA" for delicate items, "LOW ENERGY" for lightly soiled items and "RINSE ONLY" for items that will not be washed immediately.
  • hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | AEG Dishwashers
    After selecting wash cycle,I push start button. washing light comes on for a second then goes off.start light keeps on blinking. washing cycle would not start.
    check flood switch float is on(the float under the bottom rack)...also the switch under that...also you ca use a 110 volt test cord to test the inlet valve
    Aug 25, 2009 | Dishwashers
    Dishwasher hums
    empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
    Apr 16, 2017 | Kenmore Dishwashers
    OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
    I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
    Dec 04, 2008 | KitchenAid Dishwashers
    Problem starting fridgidaire model FDB1050REC2
    hello kwill8
    welcome to Fixya.
    You said, You just installed the dishwasher and the only cycle it will go through is the rinse cycle. When You turn the dial to any of the other cycles:pots&pans, normal, light wash and upper rack, the start button as well as the heat dry button and the high temp button do not work. only button that will light up when pressed is the delay button. How can you fix this?
    Is this your model FDB1050REC2This is a brand new model and you said you just installed it!
    If it is brand new!
    You do not have to fix it.
    You have a full years warranty, parts and labor!let them fix it no cost to you.
    The first thing they will do, . You can do your self!
    Go to the breaker and turn it off for 5 minutes and then on again. This should reset the system and this usually is the end to most bad starts!
    try it!
    Huuum
    Oct 03, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
    Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
    281 people viewed this question
    Top Frigidaire Dishwashers Experts
    Carmen Mikulic
    Archie Ferrarini
    Archie Ferrarini
    Mike
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
