Question about Epson Stylus Pro 4800 InkJet Printer
After multiple head cleanings one color still does not print.
Plenty of ink in cartridge.
  • frank674 Nov 12, 2008
    Thanks for your response.  I ran a dozen nozzle checks.  They showed one color from one cartridge was not printing.  I performed many Head Cleanings and many Nozzle Checks.  Yes, I know I wasted valuable ink.
    This has been happening more lately.  I will now run print tests every day whether or not I will use the Epson.
    I finally performed a Power Clean and that took care of the problem.
    Thanks for your concern
  • 33 Answers
Please explain your problem. Do you get a good Nozzle Check? Do not do a bunch of cleanings...you might be just wasting ink.
Posted on Nov 12, 2008
  • Kevin Nov 12, 2008
    You may have to replace the Damper (Dumper) that feeds the printhead. If it's starting to fail, you will have continual ink feed problems. It may work for a print or two, but will give out again during a job.
Don't print the black color
Doing reference on your issue. Double check the ink cartridge to make sure that the cartridge is correctly installed. Also be sure that the black ink cartridge used is compatible with the machine.
The next thing to do is a cartridge cleaning as the belief is that the print head is blocked. If you have done a thurough cleaning, the next thing to do is replace the black ink cartridge to be certain the ink cartridge is not faulty.
I have included print head cleaning instructions in case you have not done this cleaning process.
here is some information from the Brother support site:
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may solve the problem.
Cleaning the print head may solve the problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then choose ALL.
When the machine completes cleaning the print head, press Color Start. A Print Quality Check Sheet will print.
Brian
Jan 22, 2011 | Canon MX700 Office All-In-One InkJet...
I have an HP color printer. When printing the black does not print well even though it shows that the black print cartridge has plenty of ink in it. Is there a way of: 1. Diagnosing if it is the print...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 11, 2010 | HP Deskjet F340 All-In-One Printer
I have a Dell 926 All-In-One InkJet Printer, I put a new black ink cartridge in the printer; still have plenty of color ink. When I have a document that I want to print from Word, it will sound like its...
Make sure you've removed the shipping tape from the cartridge's print head. More than likely the black cartridge is not disbursing ink - clean the print head carefully with "Q" tip and alcohol and see if black ink comes out slightly. Re-insert cartridge and try again. Perform "clean cartridge" in printer properties window.
Nov 03, 2010 | Dell 926 All-In-One InkJet Printer
It won't print black ink even with new cartridge and multiple cleanings
Hello, and thanks for using FixYa.
Sounds like the print head carrier, the printerhead has its black cartridge nozzles blocked, due to dryed up ink. Remove the back cartridge and Check the area under it, does there appear to be wet ink? if there is, then the cartridge is working but the nozzles are blocked. If the print head is removeable you might try to sink the bottom a bit in warm water to get the ink to dissolve from the nozzels. It should print after that.
just make sure the head is clean and dry before placing it back into the printer.
let me know how you get along with it.
Oct 20, 2010 | Brother MFC 490cw Color Inkjet...
Printer been standing a while plenty of ink but will not print
The ink has probably gelled (become solid) in the nozzle. You can try cleaning the print head and cartridges manually. Remove the cartridges from the unit and wipe with a damp paper towel (dampen with water). With the bar code facing you, wipe the bottom of the cartridge horizontally, moving the towel only from left to right. This is where the ink comes out. Continue until it looks clean. Then dab the cartridge on the towel to see if ink comes out.
With a damp cotton swab, also clean the bottom of the shiny piece of metal underneath the contacts at the back of the carrier where the cartridge fits into the printer. This may take multiple swabs.
Reinstall the cartridges and follow the usual procedures. If the cartridge didn't come clean with wiping, you can build a declogging tool with a syringe (no needle) and a very narrow diameter piece of tubing. Cut a short length, place the tubing against the holes in the cartridge nozzle and pull back on the plunger. (This has to be done carefully to avoid damaging the print head.) Look online for information on the syringe and tubing size - it will depend a bit on the cartridge hole size.
Final option - new cartridge.
I hope this helps.
Apr 25, 2010 | Lexmark JetPrinter Z605 Color InkJet...
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
Printing very light
I am not sure your printer cartrige with head or not, and it is color or black, it there any color lost, in general you may try
1) if the cartridge seperate print head, find a cartridge spacial clean liquor or steam water and take out the ink cartridge, put a little into the ink hole and back the ink box test it,
2) if printer ink with head, take out and put in team water (just touch water surface to the head hole for 1 Hr. and then put back and test.
3) check printer manu adjust darkness to darker.
Dec 28, 2008 | Lexmark X75 All-In-One InkJet Printer
Colors are not printing out true.
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Dec 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Epson Stylus Pro 4800 InkJet Printer Logo
174 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
