Question about Plantronics Lands Phones
How to make a pause - Plantronics Lands Phones
    Scholar:
  • 63 Answers
Common "PAUSE" buttons are P, a comma "," , or the old fashioned method of waiting for a few seconds.
You might have an ALT key or SHIFT key. Try that.
Posted on Nov 11, 2008
Pauses randomly during films, all front buttons play/pause the dvd
Maybe one or more buttons jammed or wet inside.
Try opening front panel and clean the contacts. If problem persists then it is the buttons controller IC/PCB faulty.
Feb 04, 2018 | Televison & Video
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Dec 25, 2009 | Televison & Video
Constantly getting pause,pause.pause
if your pointer on video screen when you press button then it pause the video click on simple play button and check your mouse pointer or download opera browser kkkkkkkkkkkkkkkkkk
Nov 04, 2009 | YouTube Videos
How can I enter a soft (2 sec.) pause in a contact number on A766
1) From the Home screen, go to Start > Contacts
2) Select the desired phone number
3) Press the Menu soft key and select Edit.
4) Use the Left or Right navigation key to place the cursor at the place where the pause needs to be added.
5) Press the Menu soft key and select Insert Pause to add a two-second pause. The letter ‘p‘ will appear where the pause has been set.
6) Use the keypad to enter any additional numbers if desired.
Tip: You can create pauses longer than two seconds by entering multiple pauses.
Aug 01, 2009 | Samsung Propel A767 Cell Phone
Pause function for RCA Lyra RD1072A.
This player does not have the true pause you are looking for. The iPod Nano - 2nd generation - has a true pause - once you hit pause it will stay paused and even go to sleep. When you revive the player it will leave off where you left it.
Dec 08, 2008 | SanDisk Sansa e260 MP3 Player
Pause in dialing
hit the # (pause) 2 times. it will change to a P. I had to put 2 pauses in my string
Apr 22, 2008 | RCA 25202RE3 Corded Phone
Permanent pause
It might be that the memory chip is fryed and it thinks that you are hitting the pause button, or eather it is that something is caught in the pause button. Take it a part or find something that will fit in between the pause button and clean it.
Jul 14, 2006 | SanDisk Sansa m230 MP3 Player
Lands Phones Logo
76 people viewed this question
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
