Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
Pilot Light Goes Out
I have a Cozy VC701A-R and It will light and burn fine for a while, but the pilot light will go out when the thermostat cuts off the burners. What can I do to solve this problem?
  • devs5 Apr 24, 2009
    I have a timberflame IB35 ETR. When it heats to the right temp and drops back to the pilot lights it will occassionally shut down completely showing error 11. Once this happens it is almost impossible to get restarted. Have had it serviced a couple of times, goes ok for a while then it starts happening again. What can I do. Is there an adjustment I can make?
  • 1,420 Answers
The VC701 has a safety switch located on the back of he heater that may be tripping after the call for heat is satisfied. Check that there is a good draft by testing with a match. Make sure the flame is drawn toward the vent system when the unit is off and cooling down. Check it at the draft diverter located below where the vent pipe is attached. It is a box with an open bottom. If the draft is not pulling air toward the vent system, the heat from the cooling heater will trigger the safety switch and shut off the pilot. You may have to raise the vent pipe to establish a draft.
Posted on Sep 24, 2007
I have a Cozy W355D wall furnace. It's difficult to turn on. Replaced the thermostat, that helped some, but still have to turn it off, wait a few minutes, and turn it back on. Often still won't light.
So are you saying the pilot stays lit, but the main burner won't always fire. If this is a millivolt system you could have a weak pilot flame, not getting the pilot generator hot enough or you could have a weak pilot generator. If you are handy you can try cleaning the pilot. It may be better for a qualified service tech.
Jan 30, 2017 | Cozy Heating & Cooling
Where I do I light the pilot light on my Cozy Wall Heater? I know it needs to be lit somewhere on the bottom of the unit but I cannot find the spot and my heater will not turn on. I am a senior and not...
in front of the burner it is next to a copper tube(black if it has been burned)! it angles a little towards the copper tube! u turn the knob on gas valve to pilot then hold down and light hold for one minute then turn it to the on position (u might have to push down slightly as u turn the knob) make sure u have thermostat to the lowest setting before u light the pilot so it won't turn on while u have your face too close to the heater then turn your thermostat up to desired temperature when it is on the the on position! Good Luck!!
Nov 07, 2010 | Cozy (W352E) Heater
New Cozy Enclosed Front Console 70,000. Pilote goes out, gas stay
its not the valve you have a problem with the heat exchanger a baffle issue have to change.
Feb 13, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Feb 02, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Every time the thermostat tries to switch the heater on, the pilot light goes out. Cozy natural gas mod # CDV 335A
remove the thermostat wires from the gas valve and put a wire accross the outer terminals if unit starts up the stat or stat wire is bad.
Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Nov 08, 2008 | Cozy (W352E) Heater
Cozy furnace
The pilot orifice could be dirty causing the pilot flame to be too small. Unscrew the pilot tube at the pilot assembly. The orifice is inside. Remove the orifice and blow it out with compressed air only. Reassemble and see if that fixes the problem. If the pilot flame is set too low, sometimes opening a door will cause a draft to blow out the pilot. If the thermocouple is good and the pilot flame is set properly, the control valve may be bad.
Oct 22, 2008 | Cozy Enclosed Front Console Heater 70,000...
Cozy wall heater lights fine then goes out after 3 or 4 minutes
Make sure all the wire connections are good and tight. Next lift off the cover and look for a little thermal disc mounted up by top of the heat exchanger. Most have a re-set button but not all. If you have this ,by-pass it ,see if that solves the problem, if so it may be defective, or doing its job and you have a venting problem. If you don't have this and have changed the thermocouple (was it a copper tube with a fitting that screwed into the gas valve, or did it have 2 wires, that is a pilot generator, kind of same thing) make sure the probe is set correct, with the pilot flame heating the top 1/3rd of the probe. The only thing left is the gas valve.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
409 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
Paul
Paul
Marvin
Marvin
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
