Question about Kenmore 50522 / 50524 Side by Side Refrigerator
We have had water leaking on the floor for 3 weeks now. We have checked Ice Maker, water depenser, and even disconnected all sources of water to refrigerator. The refrigerator is a Kenmore.
    Problem Solver:
  • 8 Answers
Check the pan on the bottom of the fridg. the hose could of slipped out, this runs from the freezer section to the pan, when it goes into defrost water goes to the pan
Posted on Nov 11, 2008
Water leaking and no water to ice maker?
pull fridge out
unplug
turn off supply faucet to ice maker
check line and fridge connection for the leak usually at the frige.
repair as necessary
turn on water
check for leaks
Mike
May 11, 2016 | Refrigerators
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Water leaks from freezer on floor.
Hello. May be the ice maker is overloading water. Is simple to regulate. You must take away the front cover from the ice maker, then will see a regulator screw, move it about 1/2 turn to minus posicion and check if water still leaking from the ice machine
Oct 20, 2014 | Whirlpool Refrigerators
I have a GE model TPX 24BPBA WW and have a water leak on my floor. I disconnected the icemaker water feed and leak stopped. What's wrong
do you live in an area where there are rodents such as mice ? if yes there is a possibility that they have eaten the plastic water line that feeds from the ice maker water valve to the ice maker itself . when they get thirsty you would be surprised what they will actually chew through to get water. regardless the cause, you probably have a broken water line between the ice maker water valve and ice maker unit .
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Have a Frigidaire with an ice maker that is leaking. Can't find the source of the leak but am getting water on the floor when it is turned on.
might be the ice maker unit damage might be the fridg not level , might be the valve of the ice unit damage and not stop dripping... check all this and let me know...
Dec 29, 2009 | Refrigerators
Ice maker leak
sounds like you have a bad water valve,if the ice maker is disconnected and water is still filling the ice maker cup the valve is bad
Aug 19, 2017 | Electrolux Frigidaire Professional Series...
Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Feb 03, 2009 | Sub-Zero 561 / F
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
