Question about HP DeskJet 5550 InkJet Printer
Paper feeding problem in printer
I have a HP Deskjet 5943 printer. Printer is not taking the paper from the feeder. some times it got stuck up. Paper guides and rollers are perfect. Please give me a solution
Maybe the ramp that takes it to the rollers has broken
Posted on Jun 17, 2007
SOURCE:
HP F4280 All in one Printer. Feed jammed (AVERY 8376 Ink Jet Business Cards); printer made noises, finally stopped; pulled paper backwards out of printer. Turned the printer on and the cartridges bang...
Well it's likely two cause in your case -
1.- It might be a misplaced actuator, check for instructions at:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&product=58057&dl...
2.- Check the power supply and its cable. It might be at the end of its life. Ideally, you should check the power supply under load at its limit. You may use a resistor rated for the load. It will be HOT, be careful. If you don't have it, might be more cumbersome, but you can use the printer as load, and make a test connector that allow you access to voltage terminals.
Good Luck!!
Thanks
Sep 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
Paper light on
Unplug the printer, open the lid, make sure there is nothing jammed in the feeder. Then take the paper out of the feed tray, straighten it out again, and then re insert it into the paper tray and power up. I have the same printer and this has happened to me several times before. If that doesn't work, chat with HP tech support for this series printer @ http://h50203.www5.hp.com/hpisweb/customer/HPInstantsupport.aspx?&cc=us&lang=en
Aug 25, 2009 | HP DeskJet 9800 InkJet Printer
Hp deskjet constantly says out of paper. As far
Each printer has a sensor that determines when there is no paper, on cheaper printers like deskjets it tries to feed the paper and when it fials it gives this error. The feeder for the printer is most likley bad, replcaement is the most cost effective solution , repairing it would be more then a new unit.
Aug 25, 2009 | HP DeskJet 612c InkJet Printer
Hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Aug 10, 2009 | HP DeskJet 6122 InkJet Printer
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
HP Deskjet 3940 (Paper Jam)
I have a HP Deskjet 3940 printer. And similarly to this problem here I had a paper jam that would not clear, despite removing all the paper that was stuck in it, and following all 4 steps stated on the HP website. Such as taking the back cover off and blowing dust away and turning it off and on, etc.
None of these steps worked for me and consequently I couldnt get any new jobs to print - kept saying 'paper jam'. I was about to head down the shop to buy a new printer when i tried one last thing, which HAS fixed the problem!
I put in a large stack of paper onto the feeder. and then pushed it forcefully in and out repeatedly. To my amazement this has solved the paper jam. As a very last resort, might be worth trying this?
Jul 25, 2008 | HP DeskJet 3940 InkJet Photo Printer
HP DeskJet 820Cse printer problem
You could try cleaning the rollers with some soap and water. Make sure the power is off first.
Jun 27, 2008 | HP DeskJet 820Cse Printer
Paper feed problem
usb port or printer adapter problem.check both of them.wish success
Jun 04, 2008 | HP Deskjet 2360 InkJet Printer
Missing Tool box software for HP Deskjet 690C
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=58156&lang=en& Check the paper feed area for loose debris or a stuck piece of paper. Good Luck, Tim
Feb 10, 2007 | HP DeskJet 690c InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
165 people viewed this question
Clive
Clive
Thomas F. Schneider
