Question about Frigidaire GLER331A Electric Dryer
Changing cord from 3 prong to 4 prong on frigidaire dryer
Got dryer as gift which has 3 prong but outlet in wall has 4 prong.
  • 5,911 Answers
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Posted on Nov 11, 2008
I need to know how are you change a 3 prong outlets is a 4 prong outlet frigidaire dryer
Posted on Nov 14, 2011
  • dfenton52 Nov 14, 2011
    I need to know how are you saying to 3 prong cord and m to 4 prong cord on the back of a frigidaire dryer
I have a 3 prong wall mount outlet for my dyer and want to put in a 4 prong. how do I do it?
Veronica,
If you are talking about the outlet you plug your dryer into, that would require an certified electrician to make the change since that is covered by electrical codes. If you are talking about changing the pigtail on the dryer, you could do that yourself. Just remember to take the brass strip off that goes from the middle of power cord block to the ground. You have to separate the neutral from the ground in a four wire situation. Hope this helps!
Mar 06, 2015 | Dryers
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
I have a dryer that has a 4 prong plug in i moved the place has a 3 prong plug in change the cord to a 3 or find adapter it is a frigidaire fde546res1
get a 3 prong cord,when you change it out do one wire at a time and you can't go wrong,you should see a white wire in the middle,a red wire on one side and a black on the other,the only difference is the 4 prong has a ground wire on it and the 3 doesn't and the way it plugs into the outlet.just follow the color of the wires
Mar 20, 2011 | Frigidaire FDE546RE Dryer
I just moved and have a standard 3 prong outlet in my laundry room, the dryer has a 4 prong cord- what kind of replacement cord do I need to buy that will make the electricity of both the dryer and the...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman'; mso-fareast-language: EN-US; mso-bidi-language: AR-SA" lang="EN">Here is a tip that will help you with changing your dryer plug.<br /><br />Dryer Cord and Wiring Dryer 3 Wire or 4 Wire<br /><a href="http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire" target="_blank">http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span>
Aug 26, 2010 | Frigidaire Dryers
Need to change 4 prong drier plug to fit 3 prong eletric
Purchase a 3 prong dryer cord. It is simpler and safer than changing the wall outlet.
Nov 03, 2009 | Dryers
I have a wall outlet that is made for a 4 prong dryer and i have a dryer with a 3 prong, i went to the store and bought a new cord besides knowing its for a dryer do i need to know anything else, i bought...
When you put the cord on the dryer,the white wire goes to the center wire terminal. Black and red go to the 2 outside terminals right and left. The Green ground wire attaches to a ground screw outside the terminal cover.
Oct 08, 2009 | Frigidaire FEQ332E Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
I have a 4 prong power cord coming out of my Kenmore dryer and I have a 3 prong power outlet in my wall. Can I replace the 4 prong cord with a 3 prong cord, and if so, how?
Purchase a 3 prong cord at a home improvement center. and replace your 4 prong cord. all you need is a screwdriver.
May 02, 2008 | Dryers
Frigidaire GLER331A Electric Dryer Logo
3,916 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
