Question about Hitachi 43FDX15B 43" Rear Projection Television
Replaced the board
He replaced the board, with the new ic's, and resistors. Now it just beeps. no sound no picture no anything. He said" I don't understand that", and walked out the door. Please Help.
    Genius:
  • 1,153 Answers
There are many small fuses on this set. Did he replace? and what board did he replace Small Deflection or signal? No sound and pic and beeps mean that standby is trying to work. Look for power supply problems and vertical problems Also audio problems, Meaning IC's of all first.
Posted on Sep 05, 2007
ICs + resistors swapped= blue power light auto on clicking noise
Unplug the power to the convergence board. If it turns on, you still have a problem in the convergence circuit.
Dec 16, 2009 | JVC AV-56P575 56" Rear Projection...
Black picture, perfect sound
hi...your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 large IC's , probably STK392-040, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps u alot...
thank u!!!
May 25, 2009 | Samsung LN-T4665F 46 in. LCD Television
Picture comes and goes by itself. I get sound but no picture
thank u!!!
May 24, 2009 | LG 32LG30 32 in. LCD HDTV
Picture bends in different colors
your Convergence IC chips and resistors arre failing you need to replace them
below is a general disscussion post for a Philips TV which will help you to understand your situation and what you might need usally you will need (2) IC convergence Chips and usally (12) Resisitors what have to be soldered onthe the board after you remove the old ones. this fix usally cost you to do it yourself $30, to have a repair man do it cost around $300-450 a new board if avalible usally costs $250-300
Sorry, for the bad new I hope you have a friend that knows how to work on circuit boards...
good luck,
below is a general post about a philips TV Convergence problem you can read about keep inmind your CHIP and RESISTORS will proball be different type....
you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC
chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Nov 20, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Magnavox
Need more info, does it click on and off, make any noises, was the picture going blurry, did you just move it, was in built into a wall where it wouldn't get air to cool???
Here is what I know about the 51mp392h this is a general post below I used for some other peoples fixes without more info on yours I suggest reading thru the below and links and add more info to your post so we can trouble shoot it.
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
What you need:
(2) STK392-120 OR STK392-150 IC chips
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
No Picture No Sound Magnavox Rear Projection Television
51MP392H/17
What you need:
Nov 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips rear projection tv-wont turn on
Sounds like your Convergence chips failed, were your red/blue/green colors slowly seperating or was the picture starting to curve on the top or bottom or both? if so see below general post.
Also what model # is your TV and what size?
51MP392H/17
What you need:
Nov 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Power up issues
Bad new convergence amp IC's......What part # did you use
and what quality were they ?................read some of my
convergence repair solutions........................T.
Mar 06, 2008 | Philips 50PP9202 50" Rear Projection...
Tv has soun but no picture
51MP392H/17
What you need:
chips
Nov 05, 2007 | Philips Magnavox 51MP392H Rear Projection...
Convergence green lines
Closely inspect the board for poor solder connections. Also someitmes the resistors will not show any signs of being bad even though they are open. It is wise to measure them but you need to disconnect the convergence yoke plugs to ge a good reading.
Sep 04, 2007 | JVC AV-48WP30 48" Rear Projection...
Hitachi 43FDX15B 43" Rear Projection Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
