Question about Jenn-Air JES9800AAS Electric Kitchen Range
2003 Jenn-Air Electric JES9800AAS burners not working properly
About 3 weeks ago, the right side burners on my range stopped working properly. I had thr front burner set to low, yet cooked on extra high, and the rear burner, which was off completely, was hot to the touch as though it had been used as well. That left us cooking only on the left side of the stove for the past few weeks. Now, that side has started the same thing! Please help! Even on the the lowest setting of the small inner burner, my food burned to a crisp! YIKES - turkey day is almost here and I don't have a job to buy a new stove. Any help and info would be greatly appreciated!
5 Suggested Answers
SOURCE: Installation of down-draft exhaust duct for Jenn-Aire cook top
Minimal 6" duct no more than 20 feet long and 90's count as 5 feet. 90's must not be closer than 18" this will meet local codes regarding the venting also an approved exhaust hood. (not a dryer vent)
Posted on May 22, 2008
aborcass
  • 2651 Answers
SOURCE: Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Posted on Nov 04, 2008
SOURCE: Oven shuts off
replace oven temp.sensor
Posted on Nov 20, 2008
SOURCE: jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Posted on Jan 16, 2009
I have a Jenn Air S160 stove and the burners stopped working. Is there a reset button? The grill does work on one side but the burners do not. Thanks, Pam
Try switching the grill to the other side if it works the ceramic burner is bad replace the ceramic burner. burners and grill coils unplug when you pull them out. The left one pulls out from the front the right one pulls put from the rear. you can enterchange the burners on either side.
Oct 07, 2010 | Jenn-Air Kitchen Ranges
The fan works until the oven starts heating up, oven is putting out a code F11
From the tech sheet:
Fault
Code Description Component to Troubleshoot/Replace
F1-1 Oven temperature above 650° F (343° C) in bake mode. Ohm sensor and harness (see "Oven Sensor" chart).
If OK, change control.
This may be due to your fan failing or a problem with the control board. We rebuild these controls at fixyourboard.com.
Aug 14, 2010 | Jenn-Air JES9800AAS Electric Kitchen Range
Burners are dry, but won't stop clicking
Hello, Jesse -
The information on this website may explain why the electric starter for your gas burners click:
https://1stsourceservall.wordpress.com/2015/08/07/why-does-my-stove-keep-clicking-troubleshooting-a-gas-stove-ignitor/
Best wishes.
Feb 07, 2018 | Jenn-Air JDS8850BD / JDS8850BDB /...
Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Mar 02, 2008 | Jenn-Air JES9800AAS Electric Kitchen Range
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn air pro range 36" prg3610np
hi after the burner ignites turn knob until it stops trying to ignite thanks
Jan 07, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Jenn-Air JES9800AAS Electric Kitchen Range Logo
97 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
