Question about Whirlpool Duet GHW9150P Front Load Washer
Fabric softener dispensing before wash begins
Fabic softener starts running into machine as soon as I close the dispenser drawer. Sometimes it's very gross and "gloppy" sometimes not. Sometimes it is accompanied by the detergent, sometimes not.
  • 6 more comments
  • msdjc Dec 06, 2008
    I've had my washer and dryer for about 6 months and I love it, except...I just noticed the other day that the fabric softener is emptying into the washer at the same time as the detergent. Somehow that is not right. I've seen someone else post this problem. Do I need to call Whirlpool?
    Donna Campbell
  • msdjc Dec 07, 2008
    same problem. softener dispenses along with the detergent.
  • Anonymous Jan 11, 2009
    Fabric softener dispenses before wash begins.
  • jlmcclure827 Jan 29, 2009
    just noticed today that the fabric softener was dispensing before I even got the door shut. Soap wasn't though
  • DGLC Jan 30, 2009
    Fabric softener is dispensing into wash at the beginning of cycle, not detergent.
  • fultonmotes Feb 06, 2009
    My fabric softener dispenses when i start cycle & laundry detergent never dispenses during wash.
  • Anonymous Feb 08, 2009
    Mine has always done this. Both the detergent and softener dump in together at the start of the wash!
  • Anonymous Mar 13, 2014
    how to clean fabic softener container
I was having the same problem. Repair man replaced VALVE AW
He told me it is from the sedement in your water. If you have a water softner, it may not be the problem, unless it is not working properly. Sounds strange, but problem is fixed.
Posted on Feb 07, 2009
I am having the same problem with the soap and fabric softner dispensing into the washer together... before I even shut the door. Shouldn't the softner dipense in the rinse cycle?
Posted on Nov 13, 2008
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ... > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ... > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Iwd71250uk fabric softener staying in dispenser.
Compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow the grid.
Cleaning the detergent dispenser drawer
Remove the dispenser by raising it and pulling it out (see figure below). Wash it under running water; this operation should be
repeated frequently.
25825864-ineink0kisfnom0atbkujjcx-3-10.jpg 25825864-ineink0kisfnom0atbkujjcx-3-3.jpg 25825864-ineink0kisfnom0atbkujjcx-3-6.jpg
Aug 17, 2015 | Indesit Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener and bleach dispensers
Call the tech. one came out this week and said the system solenoid is always engaged causing the bleach and detergent to dispense when drawer is pushed in
Jan 30, 2009 | Whirlpool GHW9400 Front Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Nov 03, 2008 | Miele W865 Front Load Washer
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Detergent and fabric softener dispense at the same time
Whirlpool has designed this drawer as a siphon feed and soap and softener go as 1, 2 punch followed by bleach mid cycle.
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have the duet ht and when I fill the soap and fabric softener dispenser at the beginning of the load they both run out. Shouldn't the fabric softener be released with the rinse cycle?
pull drawer completely out by pressing release tab on left rear of drawer remove all the cups and clean thoroughly with damp rag wipe upper portion on opening before reinstalling drawer
Aug 07, 2008 | Whirlpool Washing Machines
Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
762 people viewed this question
Dan Webster
Dan Webster
Sal De
