Question about Belkin Wireless-N Wireless Router with 4-Port Switch
My Belkin F5D8053 is working in low strength
I wanted to run a movie and the wireless Belkin was running to low. Online work has also been running very slow. Do you have any suggestions?
  • Belkin Master
  • 6,487 Answers
If you're encountering a very internet connection on your router, this is can be a problem with either the internet connection from your modem or the firmware of the router should be updated, first thing that you can try is to update the firmware of the firmware of the router, you can download the latest firmware of it from Belkin web site then after that observe the connection if you still have a slow internet using the router , Try to check now the internet from your modem by connecting a computer directly to your modem and if you still have the same problem internet connection from your ISP is the problem so you can contact them about that..........
Posted on Nov 11, 2008
What's N stands for in this product (Belkin F5D8053 N Wireless USB Adapter for Desktop or Notebook PC)?
Based on the 802.11n draft, N Wireless enables multiple receivers and transmitters to send and receive data using Intelligent MIMO (Multiple Input Multiple Output) spatial multiplexing techniques which greatly increases speed, coverage, and the reliability of the wireless network.
Sep 25, 2012 | Belkin F5D8053 N Wireless USB Adapter for...
My belkin n USB adapter (f5d8053) has been unable to access the wireless internet at my new place, through the mwn-apr150n medialink wireless n broadband router. My other devices connect fine, it's...
Please check the Network Range B/G/N Signal.
This could be the issue if other aplications are able to connect.
Also try to delete Wifi Profiles using the USB and add fresh wifi networks
If not in install & reinstall the the USB Software on ur pc / laptop
Lastly if this doesnt work try to use the USB Adapter on another network / other device and try to connect
If it doesnt then u have a USB Issue
Cheers
Eddie
Jul 02, 2017 | Belkin Computers & Internet
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't get online, even though computer says connected
As the router is working and connected to the internet - then its probably and issue with the wireless setup on router or your PC
1) remove any wireless profiles on your PC read here - how to do that http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm then when reconnect it will ask for the key again 2) A firewall maybe blocking your access - disable any firewalls 3) Remove the wireless security if enabled in the router and see if you can connect - if this is the only wireless device connecting - it may interference try also changing the wireless channel in the router - use 1 or 6 or 11
Mar 14, 2010 | D-Link Computers & Internet
Inttalled belkin wireless adaptor, says strength is good, but not valid ip
the work of a belkin adapter is to receive the wireless signal in and around the adapter when pluged into computer
if ur able to see the wireless network then ur adapter is working fine
check the ip as
start>control panel>network connection>rite click on wireless network>click properties>choose internet protocol tcp/ip (highlight it and click on properties) then "obtain ip address has to be checked"
then cllick OK and try going online --- u must access the internet
Feb 20, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
Slow connection speed
Blu Ray players, draw alot of interference into the wireless router. Try moving your router into a different place, or somewhere away from your Blu Ray player.
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
Wireless hub
I had the problem that,even though the hdd connected it would fail after a period of time (video streaming or file transfers). Set up was Samsung Q45 running wireless g connected to a belkin draft N Router. 3 other PCs (all g) using 2 different OS (Vista and Mac) had same problem.
Solution after months of searching, problem solved. Fitted Draft n PCMCIA card, and to ensure it was running at 300Mb had to use WPA PSK + WPA2 PSK security mode . Now works brilliantly and has managed to stream a full HD movie!! The Wireless link is now running faster 10Mbs compared with 4Mbs on g, although not fast it at least enables the HHD to be used in a stable configuration. Problem seems to be that the unit will not work properly unless wireless n link is used.
May 18, 2009 | Belkin Wireless USB Hub
Conecting to wii
Let me understand you cant access the internet through the belkin router?
Do you know the ip address of the router?
What model belkin is it?
Jun 07, 2008 | Belkin (F5D5231-4) Router
Signal strength very low. Belkin ADSL2 modem with wireless g router F 507632-4
signal is bouncing off doors and walls to get to your comp
move comp closer to modem if it increases and your signal strength increases then you know youll have to be close to modem
other problem someone taped your signal and it working off of it call your provider to come out test the wireless signal strength and or password your wireless router settings so some one cant interfere with signal
i dont like wireless myself in the home i go straight cable with ether net cord this always has strenght and cannot be tapped
May 09, 2008 | Computers & Internet
Dead equipment
Belkin USB wireless N adaptor, I would try to update the driver (did you change anything like system restore, or upgrade to vista?) - also check it on another computer to make sure it is the adaptor and not something else going on. Died is a vague term. You can get the manual and the updated drivers at:
http://www.belkin.com/support/product/?lid=en&pid=F5D8053&scid=223
Mar 28, 2008 | Computers & Internet
Open Questions:
Belkin Wireless-N Wireless Router with 4-Port Switch Logo
323 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
