Question about Radio Communications
How to reset a yaesu FT23R
Hello ,
i'm french and i have a problem with my FM hand held .
suddenly a not conventional frequency appeared on the screen with steps that are not usual . example freq 140.004 with steps of 20 and 29.5 kHz instead of 140.000 and 12.5 and 25 kHz
what happened ? and how can i reset it ?
Hello, My problem is that I shorted my radio with the power jack. I was told to always have the plug incerted befor I turn it on. now it just blinks
Posted on May 25, 2010
Bonjour,
Avez-vous trouvé la solution à ce problème de fréquence car j'ai le même souci.
Quelle était la solution ?
Merci
Posted on May 10, 2010
  • 734 Answers
Try the given link --
http://db0sif.darc.de/cgi-bin/dpcmd?R%20YAESU%20649
Posted on Nov 11, 2008
Yaesu ft-990 no receive or transmit
Lynn, SSB (Single SideBand) only applies to AM (Amplitude Modulation) transmission. There is no way to broadcast SSB in FM (Frequency Modulation) mode.
May 16, 2015 | Yaesu Radio Communications
Eeprom error ? B0003 on display
if a reset has failed, these means either the eprom or the cpu is damaged.
Feb 11, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Ft 2900r yaesu all i see on the screen is B0001 i can't see the frequency
Try powering the unit up while holding the Set/MHz button. I did that and it restored the display (and the rest of the radio's operation) back to normal.
The character codes are test-mode displays that correspond to frequencies (in MHz):
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
I haven't the foggiest idea why this isn't in the manual somewhere, or at least flipped back to normal by a two-key or three-key reset. 73, k2mct
Sep 16, 2012 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Yaesu ftm-10e squelch problem
The FTM-10E is the european version of the dual band amateur radio capable of transmitting in the amateur VHF & UHF (144Mhz & 440Mhz ) bands, that is equal to the FTM-10R sold in the US.
Many repeaters require a predetermined sub-audible tone or signal to be sent when transmitting. If several repeaters in the area operate on the same frequency, they would all transmit at the same time unless they all have different sub-audible tones. These tones allow the user to select which repeater on the same frequency will be used. The tones are either CTCSS or DCS type. CTCSS is "continuous tone coded squelch system" and DCS is "digital coded squelch". CTCSS is expressed as a frequency in Hertz and DCS is a code expressed as a number. CTCSS is more popular, since it has been around longer. When programming or tuning the radio, you will need to provide the repeater's output frequency (and the input frequency if the shift direction and amount isn't programmed - often a 600 hertz shift either up or down depending on isn't already programmed is a default value depending on the repeater output frequency) and whether or not the repeater requires a tone. If it does require a tone (most do), you will need to know the type (CTCSS or DCS) and the value (frequency for CTCSS or code number for DCS) in order for your transmitter to open the repeater and cause it to repeat your transmission AND open the squelch on the radio's receiver so that you can hear replies to your call and other conversations. Repeater directories (both printed and online) will provide all the information needed to access a public repeater, including geographical location, input & output frequencies, squelch type and values to name a few.
If you do not have the correct CTCSS or DCS set, you will see the signal meter on the radio indicate traffic - but you will not hear anything because the radio is squelched. Check the manual page 40 for information on how to program the squelch, and page 42 describes the "shift" I mentioned above. Page 64 & 65 details the theory of squelch via CTCSS and DCS and will help you understand it better.
Basically, you have a "standard" squelch - the knob on the radio and a second squelch that is either CTCSS or DCS. Both types must be set to hear anything. Not having the CTCSS or DCS set will prevent your signal from being repeated by the repeater.
If you have more question, please add them in a comment. I hope this helps & good luck!
Jun 17, 2012 | Yaesu FTM-10R VHF/UHF Mobile Dual-Band...
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
Can't use touchscrren - i've don't soft resets - no luck cleaned the screen won't calibrate
Try doing a hard reset. To do this you can follow these steps:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm2.gif Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your hand held do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. Best wishes....Hope this helps.
Sep 16, 2009 | Palm Z22 Handheld
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
My griffin roadtrip has reset its FM frequency range
This is what a Griffin technician advised me, and it worked! (Just choose US or EU mode, depending on your location.)
Sounds like your RoadTrip has inadvertently been reset to Asian tuning mode. To get it back to EU mode, follow these steps.
1. Press the function button.
2. Press and hold the Mode button until US, EU, and JP appear at the bottom of the screen.
3. Press the button that corresponds to the EU indicator on your screen.
4. Wait a few seconds for the regular tuning screen to return.
Apr 03, 2009 | Griffin Technology RoadTrip FM Transmitter...
After factory reset of yaesu vx-5 can not get out of nfm
Check the frequency step setting. If you have it set to 12.5kHz it's possible that's forcing the nfm mode.
Dec 26, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Radio Communications Logo
1,355 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
