Question about Minolta Office Equipment & Supplies
Minolta CF 910 showing code C3310 - Minolta Office Equipment & Supplies
  • 1 more comment
  • upstate24 Nov 18, 2008
    This is not a fax machine but a commercial color copier. It is a Minolta CF 910 with a
    C3310 error code. I need to know what caused it and how to cancel the code.
    The error code C3310 does not cancel
    I did not change the LCD panel
    Sergeant:
    Champion:
  • 200 Answers
Hi
Unplug the power cord for 10 seconds.
and then try it...
If its not work means hold the printer button for five minutes and then it will turn off and then try it ...
thank you
Posted on Nov 18, 2008
    Genius:
  • 1,239 Answers
Hi If the fax machine signals an error, check the manual or call the manufacturer to see what it means. If you get a lot of communications errors, make sure the phone line is plugged in all the way and that you hear a clear dial tone through the phone receiver. If not, you might want to call the telephone company and have them check your line for interference.
  • Minolta Master
  • 1,879 Answers
Scanner related issue:
Turn of unit and disconnect scanner.
  • monk3ybidzness
    monk3ybidzness Nov 18, 2008
    The error has something to do with the scanner part of the machine. CCD or gears. Some models have cable connecting it to the main unit that can be unplugged.
    Sergeant:
    Champion:
  • 347 Answers
The LCD panel displays a C3310 code after installing PWB-C.
Solution
Cause: Connections were not properly seated on the PWB-B.
Solution: Use a small flat-head screwdriver to gently seat the connectors into PWB-B.
Source: http://www.ogator.com/manuals/AllSolutions/Color/cf910.pdf
Good luck,
Dahaka
  • Santiago Vallejo
    Santiago Vallejo Nov 18, 2008
    It is not a problem with the LCD.
    There LCD is the screen where the error is displayed.
    Theproblem is in the PWB-P conector.
    Brigadier General:
  • 3,614 Answers
The machine print head was overheating, unplug and coold down first the unit.
  • Minolta Master
  • 19,396 Answers
C3310 should be cartridge error, let me double check on the service manual.
    Sergeant:
  • 306 Answers
Make sure you are set for auto receive.. else .Unplug power cord and re-connect
Minolta CF 910 driver for 7
NO WAY That machine is very, very old. May Be ?????? maybe Windows 95 maybe.
Feb 08, 2012 | Minolta Office Equipment & Supplies
I have a Konica Minolta CF-910 which has an error code C0511. How can I fix this? Someone said something about a reset button but I need its exact location.
this is an error with the fuser unit temp there is a reset switch it is under by the interlock swith you should be able to reset it if it keeps coming up you will need to replace parts on the fuser unit it is an issue with low temp
Jan 20, 2011 | Konica Minolta DiALTA CF910 Copier
Showing code p-27
2nd Image Transfer ATVC failure
An abnormal average value is detected during an adjustment of the second image transfer ATVC value.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Sep 03, 2009 | Konica Minolta Office Equipment & Supplies
What causes the cf 910 to give c0000 and c0042
Hi
Thanks for using FixYa. Error C0000 means Main Motor’s failure to turn and error C0042 means Fusing Cooling Fan Motor failure to turn.
These errors can be due to your fuser getting stuck. Sometimes the upper and lower rollers get stuck together, or a flat spot may develop on the lower roller. Check the fuser rollers, replace if faulty.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Konica Minolta Office Equipment & Supplies
Minolta EP 3000 code M1 what is this code ? how to reset this code?
Main motor failure to turn. Check the drum and the developing unit is it is rotating easily.
Jan 15, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta CF900 code C3250
CAUSE: Worn mylar.
SOLUTION: Refer to bulletin 3135 which pertains to the transfer drum joint Mylar.
If you can find a Konica Minolta dealership that can get the part or have tech come out and look at it A VETERAN (NOT MILITARY)Tech you have legacy Minolta now Konica Minolta, CF was first generation color. The mylar is dealing with the Transfer drum the big clear drum next to the drum.
Oct 20, 2008 | Minolta Office Equipment & Supplies
Neosca63
Subject:
C0030 code is displayed and will not reset. The C0030 is referenced to the developer drive motor for the 4 developer units. developr motor is binding
hope that helps
Jul 04, 2008 | Konica Minolta DiALTA CF910 Copier
Minolta cf 2001 c13cc service code
c13cc is a code calling for a new oil coating unit. Minolta Part# 4697-151. We sell a rebuilt unit for $ 39.95. Sales Phone Number 608 884 2277 ask for Aaron.
Oct 13, 2007 | Minolta CF2001 Copier
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
