Re: HP Pavillion DV6700 - the screen is black the whole...
Try to log in safe mode then run system restore on your last good restor point. check if you see software distribution pack in every restore point then restore it on the date before you had the software distribution pack.
About it being an HP Pavilion dv6700 laptop? Ehhh, giveittome. I will use it.
Looks like I'm going to have to guess since the 'Issue' wasn't stated.
The main problem with the Pavilion dv6700, which is part of the Pavilion dv6000 series of Notebook PC's, is that all the indicator lights come up, but there are no graphics being shown on the LCD screen. The screen is black.
This is due to a graphics chipset problem, caused by a poor cooling design of HP designers.
The graphics chipset (GPU. Graphics Processing Unit), is mounted to the motherboard in a BGA surface mount.
Instead of pins coming off of the bottom of the chipset, as on the older Processors, there are Solder Balls.
The motherboard has tiny copper pads that line up to the solder balls. The graphics chipset is set into place, then heat is used to melt the solder balls, and attach the graphics chipset to the motherboard.
Due to the poor cooling design, the graphics chipset overheats, and the solder connections are partially melted. The graphics chip now has a poor contact to the motherboard.
This video shows you what's going on, and how to solve the problem,
i afraid that cause by hardware, but try to remove battery and only use the power. or press F2. if prsseing f2 the new screen(bios) open try restart and press F8. tell me is it work or not
after you turn the power buttn on on the computer, do you then turn on the button on the monitor? if you do and still get nothing on the screen, check your connrctions.
From what little information I got from you, it could be a defective battery and/or it was a dead battery. I would change the battery with a new one and if the same problem happens then we will need more information.
