Question about BenQ PB6100 Multimedia Projector
Benq PB 6200 variable fan stays on low and unit shuts down. Power temp and lamp lights flash. Where is the sensor for the fans and can I replace it?
  • 1 more comment
  • zenpj Dec 18, 2008
    I have the same Problem. How to solve this trouble.Thank Zen
  • brandt_jared Jan 03, 2009
    Power failure...found the blown cap and now bulb turns on but no pic. This is a common problem & BenQ won't answer service call...will never buy another.
  • chopkin Jan 23, 2009
    The problem is altitude. We are at 7,000 feet and operating this unit on normal settings triggers this over heating problem. We changed the settings to economic mode and have had no more problems to date. This also saves up to 20% on power and extends bulb life.
    Hope this helps someone in the future.
    C Hopkin
    IT Tech
    UCSD#1
  • 3 Answers
YES! This sensor is for sale on Ebay.... http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170296662217
Posted on Jan 23, 2009
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Sony kdf e50a10 no picture 4 red led flashes
Made around 2005---It should have a rather large fan at the lamp---there is a thermal sensor there that looks somewhat like a temp sending unit in a auto----there is also in the wire harness a thermal fuse but that is good based on your blink code.
I would not alter the design of the fans but make sure they are not that dirty--they will slow down if dirty.
My focus would be on either the sensor for temp for the lamp being bad or the fan there being bad---both are possible.
May 28, 2012 | Sony Televison & Video
BenQ DX 650 Won't power up making clicking noise
Those units are designed to be fan cooled after the bulb shuts off. When the cord was pulled, the unit lost power and without the fan, sat there and cooked. Could be a thermal fuse, could be the bulb.
Mar 10, 2017 | BenQ DX 650 Multimedia Projector
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
Turns itself off after 5 seconds of run time. will not stay on, cooling fans work, lights up screen and shows picture, then shuts off. light flash on front right corner.
Either lamp is failing (not covered under any warranty), or the ballast has failed. Or it may be a problem with the power supply, or even the fans... What is the picture next to the flashing light? If it's only the lamp light, then either lamp or ballast, if temp is flashing (the thermometer), it will be fans, temperature sensors, main board or power supply.
Apr 22, 2009 | Samsung HL-T5675S Television
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
LCD shutting off automatically
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
Oct 01, 2007 | BenQ PB6100 Multimedia Projector
BenQ PB6100 Multimedia Projector Logo
570 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
