Question about Combi Centre DX - Mango
Baxi Boiler not firing, pilot light ok
Please help me, as BG can't.
Basically when we came back from holiday we noticed that two of our radiators had leaked. Subsequently the heating slowly deteriorated, we bled all the rads, but no heating down stairs. Turn off all the rads upstairs and we were getting heat down. Then that slowly got worse.
Called BG homecare and they said they thought it was a cold feed blockage, try draining a downstairs rad, if header tank doesn't drain viola there is your problem.
Tried this, all working fine, so I have rebled all the rads downstairs, then up, no air coming out, just water. Turn the thermostat up, flick the switch to hot water and heating, and make sure that the time dial is set to come on... nothing, you can hear the boiler click, but it doesn;t fire up. the pump is new and is working.
I'm getting really frustrated now, any help would be gratefully received!!
The boiler is an old baxi (the house is 20 years old, so prolly not changed from new), I cannot find a serial / model number anywhere on it. but if it helps the removalable panal is held in by two clips and magnets, when you take this off there is a ignition button and next to it a green switch that you click to the left which has a flame embossed onto it.
  • fairfordmick May 11, 2010
    is it a back boiler
  • Steve Smith
    Steve Smith May 11, 2010
    Hi, I CAN HELP YOU!!! :) I hope you had a nice holiday? Your boiler is a baxi WM boiler,granted it is old but so what! It's easily fixed! :) Let me ask you some questions... Is the pilot light on? I'm suspecting that you have a faulty gas valve, but please answer my questions first Thanks Steve
    Problem Solver:
  • 13 Answers
First check the pilot is alight, it sounds like it is cause you can hear the boiler click. that click is the gas vale solenoid trying to open, if there is 240-230volts at gas valve when you here the click and pilot is alight the gas valve is broken. if you test for voltage look on the gas valve and see if its 240 or 24v obviously if it 24 v check for 24 volts, let me know
Posted on Sep 12, 2009
3 Suggested Answers
  • 16 Answers
SOURCE: Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Posted on Aug 17, 2009
SOURCE: water gets hot then turns cold and runs cold then hot again
Secondary heat exchanger is blocked on sealed system side.
Remove and de-scale heat exchanger or fit new one.
Posted on Jan 14, 2010
Hiya. I have an old baxi boiler wm 38/RS . The pilot light is on but the boiler will not fire up . Can u help me
Cleaning the jet is a job ONLY for a gas fitter as it involves disturbing both the case seals and the gas pipework. DON'T RISK YOUR SAFETY, besides which if the pilot wasn't powerful enough it would continually go out.
Check (if you're competant to do so) that there's 240vac across the gas valve solenoid connections. If so then the gas valve will need replacing by a GAS SAFE REGISTERED fitter.
Jan 18, 2013 | Combi Centre DX - Mango
Instructions on how to re light my pilot light onb a baxi bermuda back boiler picture if possible thanks , i hope that will help
Feb 16, 2011 | Heating & Cooling
How to light pilot light for baxi bermuda sp3
Go to this link.Bottom of page 15 on the manual
Basically it says (turn on the power first) Turn the knob to the the star/flame marking. Push the knob in, hold it for approximately 10 seconds. Release and check the small flame is lit. Now turn it to your desired heat setting.
Jul 21, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Feb 20, 2010 | Heating & Cooling
Hi there i have old baxi boiler i was wondering
pilot has to be on all the time on this baxi ,piolt might be a bit large might need adjusting down
Oct 05, 2009 | Combi Centre DX - Mango
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
How to light pilot light on back boiler?
Hi. we have a baxi bermuda. I know that you need to hold in the silver button on the left while repeatedly pressing red/ignighter button until pilot is lit. Hold in the silver button for at least another 30 seconds.
Good luck, ours wont light anymore so was on here looking for advice.
May 07, 2009 | Kitchen Ranges
Combi Centre DX - Mango Logo
2,529 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
