Question about AudioBahn DUB200 Car Subwoofer
Adjust Amp How do I adjust my 400 watt amp for better sounding base in my car
    Problem Solver:
  • 6 Answers
Run the signal through an equalizer.
Posted on Nov 11, 2008
Adjust the receive and turn the dead key down to 1.5 watts
Then put a 40 watt modulator in line with a 400 watt amp. You will have an out put of 800 watts to the antenna. Make sure you have an antenna thats rated for it. Francis whip is a good one, Palamar, another good one.
Feb 26, 2011 | Cobra 19 DX III 40-Channels Base CB Radio
Cobra 2000 with a d 104 mic and a palomor tx100 bi linear amp...how can if possible make the amp key up with less than one watt on the ssb side..Radio has a 4 watt dead key on am and i have ajusted the...
Hi, my name is John. Adjust the radio to key 1 watt, then switch to SSB on radio,then switch to SSB on amp, key down and adjust to 1 watt on amp. enjoy !!!!!! ...hope this was very helpful....
Aug 31, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
What frequency do i need to have my speakers on??
Different speakers perform better under different frequencies.
The sound you receive also depends on the box you use, and the type of car its in. In my opinion the best sound is what "I like" not what others set.
There is two ways of finding your optimum settings.
But my favorite way is to do the following.
1) Set every frequency on radio, preamp, cross over to amp and 0.
2) Turn the volume to about 50% - 75% using a song with different types of base.
3)Adjust your base gain, sonic, boost, punch or what ever settings until it sounds it's deepest. Don't over do the gain or base boost.
4)Adjust the other setting to fine tune clear sound.
5)Add the highs to see if they match up.
6)Now fine tune the amps but remember you should only need to bring the gain up or down because you had already found your deepest base. This should be the last amp adjustment unless u realize u want it lower or higher.
7)Adjusting the equalizer or EQ on the sterio will depend on the song your playing.
Note: It's best to max out at about 80%-90% sterio volume.
"I max out at 60%, but that's because I don't like twisting and twisting to get my sound up or down." One twist and im setting off car alarms.
Mar 16, 2010 | Car Audio & Video
I have 2 kenwood 3011 400 watts rms and 12oowatts peak power each 1 is blown and wonderin about upgrading 2 the Hifonic Olympus OLM1612 would this be a good upgrade even thought i only a 400 watt kicker...
yea for sure thats a good upgrade. You shouldnt havebeen able to blow the kenwoods with 400 watts though-meaning that they probably blew from distortion which causes heat(fast) Check your gain on the amp start it out at 1/4 gain and turn up your deck to the point where you can hear distortion from your mids and highs or to the maximum level that you listen to your music at. If you're jamming out at a level that is causing distortion then you will be sending a distorted signal to the amp as well. The amp then amplifies the distorted signal through the subs which overheat and blow. So find the distortion spot and then turn it down just a little bit till it clears up your sound-then adjust your gain on the amp up slowly until you cant hear it getting any louder. Once you have done that you have reached the limit of CLEAN power that you are going to get.Thats where you want to keep it. Watch the bass boost too if you have the bass up on the deck and then crank up the bass boost on the amp it really f's up the signal too. Good luck
Jan 31, 2010 | Hifonics OLYMPUS OLM1612 Car Subwoofer
How to hook it up to system with two 10s 400 watts per sub and two 6x9s at 200 watts each?,subs behind seats, 6x9s in doors. IF i need another amp i have one,to help push. But either way i need your help...
Hello www_mitzjohn,
I'd definitely use another amp.
The 2-channel Sony is well suited for powering the 6X9's but a monoblock would be better for the subs. The different types of speakers running from the same channel will not sound very good and likely it'll be impossible to get the impedances to match.
You'll want to set the Sony to send higher frequencies to the 6X9's, but not to the subs. You can't adjust the channels individually. So, just connect each 6X9 to one channel of the Sony and use a monoblock subwoofer amp for the subs.
Hope this helps.
Oct 31, 2009 | Sony XM-2150GSX Car Audio Amplifier
How to adjust sound quality on Pioneer car stereo
If you really want more treble just invest on some tweeters...you can get a pair of 400 watt on ebay for less than $10 shipped...great way to improve sound clarity at a cheap price.
Sep 22, 2009 | Pioneer Car Audio & Video
220 watt car amp -- 8 or 10 gauge amp kit?
when in doubt go bigger, you might want to get a bigger amp down the road, so its better to not have to buy another wiring kit later.
and the bigger the wire the less line loss you will have so your amp will sound and perform better.
Apr 03, 2009 | Car Audio & Video
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Djust
alot of times its not just the amp that gives you better sounding bass.. A lot has a to do with a few other factors as well.. first off your subwoofer.. the bigger the subwoofer the deeper the bass. Some woofers exturde, or flex differently depending on the quality and structure of the woofer.. 2nd is gonna be the sub box. different size boxes will give your sub diff. depths of bass. ... general idea is the bigger the box deeper the bass. But if your woofer is not supplied enough power a big box is useless.   With that size amp your best bet is too run a single woofer. Probably a 10inch woofer would sound the best.. but it in.75cub inch. sealed box.. should sound great.
Nov 11, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
AudioBahn DUB200 Car Subwoofer Logo
44 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
