Question about Radio Shack Pro-2052 Scanner
Radio Shack Pro 2018 Scanner backlight not working
How do you replace this lamp? I have a RS Ptrolman 9 that is 33 years old and the lights still work. This 2018 is 3 years old. The employees at RS don't know anything about scanners and radios like the good old days
  • tjstraub Jan 28, 2009
    I have a Radio Shack Pro scanner and the back light does not work! I sthere a solution to correct this?
4 Suggested Answers
SOURCE: How to use the Pro 2018 Scanner
so does any know how i am on line now on how put in frequencies how to program
Posted on Oct 20, 2008
Mechanic688
  • 204 Answers
SOURCE: Antenna for radio shack pro 2018
Hello, Radio Shack would be the first place i'd try for a replacement. Mechanic
Posted on Nov 01, 2008
BillB-SA
  • 2761 Answers
SOURCE: i need to program a weather scanner for a pro 2018
Weather frequencies are factory programmed into the PRO-2018. Just press the weather button to start scanning them. You can also program one or more manually if you wish. For a list of NOAA weather broadcast frequencies, follow this link:
http://www.nws.noaa.gov/nwr/indexnw.htm
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Bill B
Posted on Sep 07, 2010
Need an replacement antenna for my radio shack pro-508 scanner. Radio shack does not carry them anymore
Hi.
Check on eBay. You need a standard BNC connector antenna for this scanner. Radio Shack scanners are made by Uniden so a Uniden BNC antenna will fit your unit.
Here's a link for an antenna on eBay:
http://cgi.ebay.com/UNIDEN-DESKTOP-SCANNER-ANTENNA-BNC-SCAN-3-/220734104369?pt=LH_DefaultDomain_0&hash=item3364c72331
Feb 08, 2011 | Radio Shack Pro-2018 Scanner
The backlight to the display no longer works. The "bulb" seems to be burned out. Is this going to be a cost-effective repair...?
The backlight in your scanner is an 8volt bulb, but your scanner is 10 years old, and the exact replacement is no longer carried by radio Shack. You can, however, replace it with a 6volt 25ma bulb, Radio Shack catalog number 272-1140. Replacing it is fairly simple if you're at all handy with electronics and a soldering iron. Contact your local RS to purchase or order the bulb, and I'm certain that they can have it installed if you're not up to trying it yourself.
Bill B
Listening in since the 60's
Sep 29, 2010 | Radio Shack Pro-2052 Scanner
I need to program a weather scanner for a pro 2018 weather scanner from rdio shack
Bill B
Sep 05, 2010 | Radio Shack Pro-2018 Scanner
Neighbor gave me this Pro-508 as it had lost it's freqency programming. I reprogrammed only to find it "instantly" loses all programming if power is disconnected. Specs say it should hold for 1 hour. ...
You can to to RadioReference.com and join the RS forum. There you will find references and manuals for just about any scanner from Radio Shack, and places to get parts.
Aug 17, 2010 | Radio Shack Pro-2018 Scanner
Need to find replacement padapter no. JoD-41U-02 for pro-2018. Can't locate one. Do you know where I can buy one.
The exact replacement power adapter for your scanner is out of production. Power requirement for the PRO-2018 is 12 volts with a minimum of 300 mA. Radio Shack has a universal power supply that will work, or you can pick one up on eBay for under $20, including shipment. You can also pick up a voltage-specific power adapter on eBay or elsewhere, but you may have to change the DC plug to match your scanner.
Bill B
May 21, 2010 | Radio Shack Pro-2018 Scanner
Very dim light on my pro 2052.
Display or backlight? If it's the backlight, you need to replace one solder-in bulb. Radio Shack part number 272-114 (5v, 25mA) will work. If it's the dispay you need to contact the Shack for a replacement.
Bill B
Feb 26, 2010 | Radio Shack Pro-2052 Scanner
Have a Radio Shack PRO 2018 that stopped working properly,Scans but necver finds anything.adjust squelch and nothing but static so it is not the speaker.PLEASE HELP
Did your local public service switch to a digital system? If so, you cannot receive digital trunking on this radio. Ask at your local Radio Shack store, or a local ham radio operator who can help you out.
Jan 12, 2010 | Radio Shack Pro-2018 Scanner
Radio Shack Pro-508. The lock out key and program
Need to do a hard reset, turn power off, then back on. Hold down [CLEAR], press the reset button on the back then release [CLEAR]. I found it in the manual for the Pro-2018.
Oct 17, 2009 | Radio Shack Pro-2018 Scanner
Radio Shack Pro-2018 scanner manual
You can download/print the manual here:
Jul 14, 2009 | Radio Shack Pro-2018 Scanner
Oct 09, 2008 | Radio Shack Pro-2018 Scanner
Radio Shack Pro-2052 Scanner Logo
278 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
