Question about Raritan Computers & Internet
Master Console II console lights keep blinking
I have 4 different computers connected to a KVM-Switch. Unfortunately, when I turn the switch on, all the leds start blinking and the monitor displays a "NO SIGNAL" message.
I tried to disconnect all the computers but one and it stayed the same, I couldn't access it.
Any help would be really appreciated.
Many thanks in advance,
Bernardo
  • bbezerra Nov 11, 2008
    Dave,
    If the said connection was jarred loose, would it make the leds in the front panel of the Master Console blink like crazy? I am not near the equipment right now, so I can't do any kind of tests. However, I think it wasn't loose, since the connectors were screwed to the body of the MC II.
    Thanks for your fast reply!
    Regards,
    Bernardo
    Sergeant:
  • 207 Answers
Bernardo,
you said you tried disconnecting all of the Computers, did you check the MONITORS connection to the KVM? Perhaps it had gotten jarred loose.
Hopefully this helps you, if not please post a comment and I will try to further assist
Thanks
Dave
Posted on Nov 11, 2008
  • David Preston
    David Preston Nov 11, 2008
    Bernardo,
    I Believe the lights you are referring to are activity lights(Without knowing the exact model I cant say for certain) but their contant blinking I believe indicates activity from the PC attached to that switch.
    They should be blinking if they are recieving a signal from that PC.
    Your problem indicates that the Monitor is not recieving the signal, thus the most likely culprit would be the monitors connection to the KVM.
    Let me know if this works for ya.
    If not comment here and I'll try to narrow it down futher
    Dave
My xbox ac adapter keeps indicating an orange light when it is switched on without connecting it to the console. When I plug it into the console and then switch the xbox 360 console on, the console gives...
Disconnect everything and reconnect it,if that doesn't work, try to hook it up in a different room. If you are still having problems, you need to contact customer support and may have to order a new power supply cord.
Sep 17, 2011 | Microsoft Xbox 360 Console
Avocent KVM switch keeps turning off and on, blinking, then turning itself off again. Is it in a display mode??? When it comes up, it will display the video output from the computer. KVM...
the switch should beep if you switch between channels or Ports.
It seems that you might want to download the manual and try to reset the unit. If this doesn't work call their support. Avocent has free support as far as I know.
Jun 03, 2011 | Avocent SwitchView 10040-SC 4-port KVM...
New IOGear GCS632U KVM inop
First, disconnect the KVM switch from the computer(s). Disconnect also the keyboard and mouse from the KVM switch, including speakers (if there is). Leave the KVM disconnected for 5 minutes.
Before you reconnect the KVM switch, make sure that the computers are turned off. Re-connect the KVM switch to the computers, and then reconnect the keyboard and mouse.
Turn on the first computer, followed by the second one. If you are still not getting any light indicator, then the KVM switch is dead.
You may contact IOGEAR through 866-946-4327.
Thank you for using FixYa!
Jun 08, 2010 | IOGear GCS632U 2-port KVM Switch
Have a GCS634U KVM that keeps failing to switch. acts like it lost the keyboard
This GCS634U was designed to work with USB keyboards and mice.
First, you need to make sure that your using a direct USB keyboard (no PS/2 to USB adapter).
Second, connect the keyboard directly to the computer and make sure that it's working correctly.
Third, check the connection between the KVM switch and the computers. Try to connect the USB cables of your KVM into different USB ports of the computers.
Last, try to use different USB keyboard to see if the issue is the KVM or the keyboard.
Try to power cycle the KVM switch. Disconnect the KVM from the computers and make sure that there's no even one cable connected to the computers.
Leave the KVM switch disconnected for 10 minutes, then plug it back in. Reboot one computer first and wait until it's fully rebooted. Turn on the second one untill all computers are fully booted up.
If same problem occur, then you need to contact IOGEAR and have them RMA the device.
Thank you and good luck!
Nov 12, 2009 | IOGear GCS634U KVM Switch
KVM will only switch one way
Please make sure that the keyboard is hooked up on the KB port of the KVM. check underneath the GCS632U for the correct console port. you will see a keyboard and mouse icon. Make sure that the keyboard is connected to the keyboard port. tap scroll lock key twice to switch between computers.
May 13, 2009 | IOGear GCS632U 2-port KVM Switch
Ntl starview codes
StarTech.com StarView SV431USB - KVM switch - USB
  • Mfg # SV431USB | Softchoice # C45933 | UNSPSC # 43211604
browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy9jbmv0l21pzhmvstywnjk0os5qcgc%3d&b=0 eval(parseJS('\rvar wcFrame = document.createElement("iframe");\rwcFrame.src = _39_/catalog/webcollage-iframe.aspx?sku=C45933&lang=en-US_39_;\rwcFrame.id = "wc"; wcFrame.name = "wc"; wcFrame.frameBorder = "0"; wcFrame.height = "30"; wcFrame.width = "155"; wcFrame.scrolling = "no";\rvar wcDiv = document.getElementById("ctl00_MainContent_wcd_wcdiv");\rif (wcDiv) { wcDiv.appendChild(wcFrame); } \r')); Product Highlights
  • KVM switch
  • USB
  • 4 ports
  • 1 local user
  • USB
  • 1U
Real-Time Availability Quantity: Usually ships in 2 business day(s). browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy9iz3mvmtj4mtitcw1hcmsuz2lm&b=0 eval(parseJS('\r\rfunction hidePNA() { $("#quantity").hide(); }\r\rfunction showETA() { $("#product-eta").show(); }\r\r$(\rfunction(){\rif ("True" == "True")\rapi.callAtlas("progress_ctl00_MainContent_stock",Softchoice.Web.WebServices.PNA.GetStockCount,"200","C45933",populateStock_ctl00_MainContent_stock);\rif ("False" == "True")\rshowETA();\r}\r\r);\r\rfunction populateStock_ctl00_MainContent_stock(stockCount){\rvar stock = $get("stock_ctl00_MainContent_stock");\rif(stockCount <= 0 ){ \rhidePNA(); \rshowETA(); \r}\relse {\rstock.innerHTML = stockCount + " In Stock";\r} \r\r}\r\r'));
  • $87.39
Qty:
  • browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy9idxr0b25zl3byb2r1y3qtchjpbnquz2lm&b=0
browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy91as9hy2nlc3nvcmllcy1sb2fkzxiuz2lm&b=0 StarTech.com's SV431USB is the reliable solution for server room and industrial computer environments. The SV431USB is a reliable computer management tool that allows you to control multiple computers from one console; minimizing downtime by making connected computers and input devices available as soon as they are attached. An all-metal, chassis provides SV431USB with a rugged and durable body that adds to the unit's reliability and dependability. The SV431USB is a true cross platform USB KVM that ensures a smooth and reliable operating experience. This integrated KVM switch also functions as an USB hub allowing the selected computer to have access to up to 4 USB devices. The SV431USB works with any operating system that supports the USB human interface device specification.
Note: This product will function as a standard KVM switch, powered by USB only. If you wish to use the integrated USB hub with high powered devices such as scanners, USB mass storage devices, or Multimedia Keyboards, the optional power adapter may be required.
Tech specs Feature Description Manufacturer Warranty Service & Support 3 years warranty Service & Support Details Limited warranty - parts and labor - 3 years - carry-in Expansion / Connectivity Interfaces 4 x USB - 4 pin USB Type B male - 4 ¦ 4 x display / video - VGA - 15 pin HD D-Sub (HD-15) male - 4 Connections 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) male - 1 ¦ 2 x USB - 4 pin USB Type A female - 2 Networking Ports Qty 4 Data Link Protocol USB Connectivity Technology Wired Status Indicators Port status, power Miscellaneous Rack Mounting Kit Optional General Device Type KVM switch Enclosure Type External - 1U Width 8.7 in Depth 5.1 in Height 1.7 in Weight 2 lbs Enclosure Color Black KVM Keyboard / Mouse Interface USB KVM Local Users Qty 1 local user Max Resolution 1920 x 1440
Feb 18, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Mouse and keyboard not recognized on second computer
Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
Aug 25, 2008 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
About the belkin 2 port kvm switch
i already have one computer hooked up to a beklin. can i hook up another
Apr 09, 2008 | Belkin F1DK102P 2-port KVM Switch
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Computers & Internet Logo
501 people viewed this question
Top Raritan Computers & Internet Experts
Mike
Are you a Raritan Computer and Internet Expert? Answer questions, earn points and help others
